skytalker Posted September 22, 2009 Report Posted September 22, 2009 Hi , Does anyone of you have the experience when doing some operation with the database ? I have an error occurs when I tried to insert oe delete the records in MS access. The error is show in this following .... " Exception occured in ADODB.Recordset: Operation is not allowed when the object is closed. Help Path is C:\WINDOWS\HELP\ADO270.CHM and context 1240653 in Verified_ver01.vi " However, the new data is inserted or deleted to the database, but the above error is also consistantly show. This error is NOT occur if I use the query command such as " Select * from XXxxxx " , but it does occur for the Insert or Delete command. If you have an experience or idea to fix this problem, please advise me. Thank you. ^.^ Quote
MikaelH Posted September 22, 2009 Report Posted September 22, 2009 I think your "Writing VI" to the database also assumes that some data should be returned, i.e. that you ran a SELECT Statement. Make sure you have the option set to not assume a response. Cheers, Mikael Quote
skytalker Posted September 22, 2009 Author Report Posted September 22, 2009 On 9/22/2009 at 8:27 AM, MikaelH said: I think your "Writing VI" to the database also assumes that some data should be returned, i.e. that you ran a SELECT Statement. Make sure you have the option set to not assume a response. Cheers, Mikael I also found another error in this following message ... " Exception occured in ADODB.Recordset: Operation is not allowed when the object is closed.Help Path is C:\WINDOWS\HELP\ADO270.CHM and context 1240653 in Verified_ver01.vi" This is occured when i used Update command. T_T Quote
