How to Open/Close PXI 2569 Relays simultaneously
prash
Hi All
In my application i am required to open/close some of PXI 2659 series relays simultaneously.
My question is whether it is possible to close/open say 10 relays simultaneously .
Presently i am closing /opening relays one by one , i want to operate it simultaneously
Regards
Prashant
Configure your DO for port operation, it'll operate on all lines at once.
Jim
  • 3 weeks later...
Jim
How DO port operation will close or open specified relays since it does not have any option to select relays at all
When you use the port write, the number you wire represents the bit pattern of individual DOs. So "1" would turn on DO 0 and turn off all others, "2" Turns on DO 1 (all others off) and "3" turns on DO 0 AND 1 etc since 3 (in binary) is 00000011.
