Add Time to the Grid lines of a Waveform Chart?
Hello
I am using a Waveform Chart and I would like to display the running time stamp on each major grid line. (LV 8.5.1)
Anyone know how to do this? A picture or a small vi would be quite helpful
thanks!!!
J
Hello
thanks!!!
J
Here you go
Here you go
I am using LV 8.5.1, so I cant open this VI.
Hopefully in your solution, there is a running time stamp for each major grid line....grid lines will move from right to left
Can you post a picture, since I cant open your VI
J
J
Sorry.
Here it is in a version you can open.
This is not quite what I was looking for
To add "Major Grid LInes" you have to go to the properties of the graph -->Scales--> Grid Lines and turn on Major Grid Lines
Once the Grid Lines are seen, I want to add a time stamp to THESE lines.
I have attached an example that shows the Grid LInes (yellow vertical lines).
But I want to know how to add a timestamp to each passing Yellow Grid Line and the application is running.
thanks
J
how do I add time to the yellow grid lines.vi
Properties >> Scales >> "Time (X-Axis)" >> Scale Style and Colors. Select the top left icon.
Yes..like that . How did you get the time stamps on the grid lines???
I want to make sure each gets a time stamp
thanks
J
As Asbo said. You have to select a scale that shows the minor markers.
