hova2010 Posted October 12, 2009 Report Posted October 12, 2009 Here is my application... I have data acquisition system that acquires a data point once every 4 seconds. My Waveform Chart accurately displays my data points on the Y- axis. What Im trying to do is format the X-axis to show the user an accurate time stamp. I have 3 charts....by minute, by hour, by week. I would like to show the 1min chart X-axis in real 1minute intervals...starting from the start of the application I would like to show the 1hr chart X-axis in 1 hour intervals I would like to show the 1 chart graph X-axis in 1 week intervals. I want to use the chart properties i.e. XScale-Multiplier, XScale-Offset, XScale- Minimum, XScale-Maximum How do I use the properties to build the X-Axis for each chart? ~J Quote
hova2010 Posted October 13, 2009 Author Report Posted October 13, 2009 Here is my attempt at the Waveform Graph Im trying to set 1 min intervals on the X-axis I will have 3 pieces of data average, std deviation, and Time My 1min intervals are not being set by the graph properly Any reason why? Jjh_waveform attempt1.vi Quote
smenjoulet Posted October 13, 2009 Report Posted October 13, 2009 On 10/13/2009 at 4:12 PM, hova2010 said: Here is my attempt at the Waveform Graph Im trying to set 1 min intervals on the X-axis I will have 3 pieces of data average, std deviation, and Time My 1min intervals are not being set by the graph properly Any reason why? Jjh_waveform attempt1.vi J, They're not being set properly because you are stripping the time info by combining the waveform into the array of random numbers. The waveform is being cast to just data without any timing info. Your net result is you have a 3 element array with no timing info, so on the graph it just shows 12/31/1903 (default "0" time for LabVIEW) and never increases. I'm attaching a reworked VI that shows the progression of going from A) where your're trying to start from to B) where I think you're wanting to go. It has 2 loops in it. Loop 1 is where you were trying to start but getting confused. Loop 2 is a rudimentary implementation of what I believe you want. I have included comments in the VI to help you out a little. Digest that for a bit and see if that helps and what additional questions it prompts. -Scott As an aside defualt "0" time in LabVIEW is actually 12:00:00 AM 1/1/1904 UTC, but your time may be a little different based on your time zone. jh_waveform_rework.viFetching info... Quote
hova2010 Posted October 13, 2009 Author Report Posted October 13, 2009 On 10/13/2009 at 5:24 PM, smenjoulet said: J, They're not being set properly because you are stripping the time info by combining the waveform into the array of random numbers. The waveform is being cast to just data without any timing info. Your net result is you have a 3 element array with no timing info, so on the graph it just shows 12/31/1903 (default "0" time for LabVIEW) and never increases. I'm attaching a reworked VI that shows the progression of going from A) where your're trying to start from to B) where I think you're wanting to go. It has 2 loops in it. Loop 1 is where you were trying to start but getting confused. Loop 2 is a rudimentary implementation of what I believe you want. I have included comments in the VI to help you out a little. Digest that for a bit and see if that helps and what additional questions it prompts. -Scott As an aside defualt "0" time in LabVIEW is actually 12:00:00 AM 1/1/1904 UTC, but your time may be a little different based on your time zone. Hello Scott this is getting closer...what I really want is the 4s data points to move across the graph while the Time intervals on the X-Axis remain fixed. Example : If my scan rate is 4s/ sec, the 15th data point should always cross a 1min interval line on the graph in real time..... So the X-axis may be like this 2:00pm 2:01pm, 2:02pm 2:03pm, etc and the 15 th data point should always match up with a 1min marker I hope Im explaining this better... J Quote
hova2010 Posted October 13, 2009 Author Report Posted October 13, 2009 On 10/13/2009 at 5:45 PM, hova2010 said: Hello Scott this is getting closer...what I really want is the 4s data points to move across the graph while the Time intervals on the X-Axis remain fixed. Example : If my scan rate is 4s/ sec, the 15th data point should always cross a 1min interval line on the graph in real time..... So the X-axis may be like this 2:00pm 2:01pm, 2:02pm 2:03pm, etc and the 15 th data point should always match up with a 1min marker I hope Im explaining this better... J Here is a picture of my Waveform Chart Im currently using...all I need is 1min intervals on the X axis. And the 1min intervals should be crossed in real time about every 15th data point (since my scan rate is 1 sample/ 4sec) thanks J Quote
smenjoulet Posted October 13, 2009 Report Posted October 13, 2009 On 10/13/2009 at 5:45 PM, hova2010 said: So the X-axis may be like this 2:00pm 2:01pm, 2:02pm 2:03pm, etc and the 15 th data point should always match up with a 1min marker On 10/13/2009 at 6:08 PM, hova2010 said: Here is a picture of my Waveform Chart Im currently using...all I need is 1min intervals on the X axis. And the 1min intervals should be crossed in real time about every 15th data point (since my scan rate is 1 sample/ 4sec) I don't agree with your statements or I'm reading too much into them. I think we need to establish whether you are wanting to use relative time or absolute time on your x-axis. Using "2:00pm, 2:01pm, etc." in your first post makes me think you want absolute time. But the general statements that every 15th point should match up with a 1 minute marker make me think relative time. 1) If you use absolute time, every 15th point (starting from 0) will not necessarily cross a 1 min mark. It all depends on when you get your first point. If your first point is at 2:00:16pm then the 15th point will be at 2:01:16pm. The 11th, 26th, 41st, and every subsequent 15 points will cross at 1 min marks. 2) If you use relative time, then every 15th point (0th, 15th, 30th, etc.) will fall on a minute marker, but you won't have the actual time of day on the axis. It will just be elapsed time from the start of your app. I'm going to assume you want #1 and that I'm just being obtuse and reading too much into your description. I've attached an example that will show this with a waveform graph. Again, for me, charts are too finnicky and limiting to deal with, at least in this instance. Let me know if this gets you closer still... -Scott waveform_graph_markers.viFetching info... Quote
hova2010 Posted October 14, 2009 Author Report Posted October 14, 2009 On 10/13/2009 at 9:53 PM, smenjoulet said: I don't agree with your statements or I'm reading too much into them. I think we need to establish whether you are wanting to use relative time or absolute time on your x-axis. Using "2:00pm, 2:01pm, etc." in your first post makes me think you want absolute time. But the general statements that every 15th point should match up with a 1 minute marker make me think relative time. 1) If you use absolute time, every 15th point (starting from 0) will not necessarily cross a 1 min mark. It all depends on when you get your first point. If your first point is at 2:00:16pm then the 15th point will be at 2:01:16pm. The 11th, 26th, 41st, and every subsequent 15 points will cross at 1 min marks. 2) If you use relative time, then every 15th point (0th, 15th, 30th, etc.) will fall on a minute marker, but you won't have the actual time of day on the axis. It will just be elapsed time from the start of your app. I'm going to assume you want #1 and that I'm just being obtuse and reading too much into your description. I've attached an example that will show this with a waveform graph. Again, for me, charts are too finnicky and limiting to deal with, at least in this instance. Let me know if this gets you closer still... -Scott Thanks Scott This seems to be what I was looking for! Yes, of course, each minute is designated from the absolute time of the previous minute (or start minute)... 2:01pm 2:02pm were just for illustration purposes. Will your graph continue to scroll to the right as the data & time fill the first page? I will need the X scale markers to continue indefinitely until the test is manually stopped. Thanks J Quote
hova2010 Posted October 14, 2009 Author Report Posted October 14, 2009 Scott Can the same concept be used for a Waveform Chart? I tried to get it to work with a Chart, but it not going well ... Can you tell me what Im doing wrong? J jwaveform_chart_markers.viFetching info... Quote
smenjoulet Posted October 14, 2009 Report Posted October 14, 2009 On 10/14/2009 at 3:00 PM, hova2010 said: Can the same concept be used for a Waveform Chart? I tried to get it to work with a Chart, but it not going well ... Can you tell me what Im doing wrong? You can try it with a chart, but you need to link the property node to the chart and not the graph. You also can't bundle the two values (timestamp and random data) like you are doing for the chart. That will give you two plots, not one plot with timing info. If you want the timing info for your data, you need to use a waveform. On 10/14/2009 at 1:05 PM, hova2010 said: Will your graph continue to scroll to the right as the data & time fill the first page? I will need the X scale markers to continue indefinitely until the test is manually stopped. No, the data won't continue to scroll after you reach the end of the graph. We've set up a fixed time axis, so when the # of points passes that fixed scale, the new data will no longer appear. The data is still there, of course; you just can't see it. If you change the end time on the scale or turn on autoscaling, you'll be able to see the data. To get a fixed time window to scroll, you'll need to manage that programmatically. I can work up an example for you, but I encourage you to continune to play around with it and see if you can get it to work. If you can figure out the how and why it all works on your own, you'll be in a much better position to adapt it in the future. If you can't get what you want by the end of the day, post back with what you have and we'll work up some more solutions. -Scott Quote
hova2010 Posted October 15, 2009 Author Report Posted October 15, 2009 Scott I thought I had my Waveform chart plotting grid markers correctly at 1 min intervals, BUT it the chart stops printing grid lines during its run. I attached an example piece of code hat shows my code. When the code is run, you will see the grid lines stop being plotted..do you know why? thanks J JH_waveform_graph_markers1.viFetching info... Quote
smenjoulet Posted October 15, 2009 Report Posted October 15, 2009 J, There are two problems with the example code: 1) The major problem is you were running at a faster loop rate (generating simulated data) than the actual time was changing, Therefore the chart was scrolling faster than new marker lines were being added. The modified VI below adds some "simulated time" to account for this. If you ran your original at a normal rate, it would look to work ok. 2) You keep adding data to the markers array, but it is mostlyd uplicate data. You are growing a larger and larger array. Eventually, all this array data and large marker list will at some point start to hurt the performance of your app. I have modified it to only add a new marker when it doesn't already exist in the list. This marker array will still grow unlimited, but at least it won't have duplicate data. You could further modify it it to have a limited number of markers in the array, say 60, by removing old markers when adding new markers. -Scott JH_waveform_graph_markers_update.viFetching info... Quote
hova2010 Posted October 16, 2009 Author Report Posted October 16, 2009 On 10/15/2009 at 8:09 PM, smenjoulet said: J, There are two problems with the example code: 1) The major problem is you were running at a faster loop rate (generating simulated data) than the actual time was changing, Therefore the chart was scrolling faster than new marker lines were being added. The modified VI below adds some "simulated time" to account for this. If you ran your original at a normal rate, it would look to work ok. 2) You keep adding data to the markers array, but it is mostlyd uplicate data. You are growing a larger and larger array. Eventually, all this array data and large marker list will at some point start to hurt the performance of your app. I have modified it to only add a new marker when it doesn't already exist in the list. This marker array will still grow unlimited, but at least it won't have duplicate data. You could further modify it it to have a limited number of markers in the array, say 60, by removing old markers when adding new markers. -Scott Hey Scott I couldnt open that last example, Im using 8.5.1 Also this new code I wrote doesnt work with a Waveform Chart, but it works with your Waveform Graph. I tried to modify your code to give me a 3 hour time span on the X-axis with 1 hr markers. Do you know why it works correctly in the Graph but not the Chart? J Quote
smenjoulet Posted October 16, 2009 Report Posted October 16, 2009 On 10/16/2009 at 6:50 PM, hova2010 said: I couldnt open that last example, Im using 8.5.1 Sorry, here it is in 8.5 On 10/16/2009 at 6:50 PM, hova2010 said: Also this new code I wrote doesnt work with a Waveform Chart, but it works with your Waveform Graph. I tried to modify your code to give me a 3 hour time span on the X-axis with 1 hr markers. Do you know why it works correctly in the Graph but not the Chart? Did you intend to post an attached VI? If so, it's missing. JH_waveform_graph_markers_update.viFetching info... Quote
hova2010 Posted October 16, 2009 Author Report Posted October 16, 2009 On 10/16/2009 at 7:09 PM, smenjoulet said: Sorry, here it is in 8.5 Did you intend to post an attached VI? If so, it's missing. With The attachment "doesnt work with chart_" .vi , Im trying to convert to a 3 hour graph (1 hr intervals) and also a 1week graph with 1 day intervals doesnt work with Chart__waveform_graph_markers1.viUnavailable Quote
smenjoulet Posted October 16, 2009 Report Posted October 16, 2009 Charts have a limited history buffer in terms of points. Right click the chart and choose Chart History Length... to change it. This allows you to set the max points the chart will hold before throwing away old data. It also enforces a relationship between scale min and max. The default is 1024 points. When using time as a scale, a second equates to 1 point (unless you change the Scale setting, similar to offest). 1024/60 = ~17 minutes. Try setting it to 11000 and you should get better results. Quote
hova2010 Posted October 19, 2009 Author Report Posted October 19, 2009 2 Question Scott: 1) The 1st picture is from your VI ,"JH_waveform_graph_markers[1].vi I have circled the divisor, "60" in the picture. Should this number, 60, be changed based on whether Im using markers for minutes, hours, or days? I have the divisor set at "60" for my minute chart, "3600" for my hour interval chart and "86400" for my day interval chart Would these numbers be correct? (see "Waveform Chart Grid Markers.JPG") 2) Using "3600" for hour interval and "86400" for the week chart, Im getting "some extra grid markers" on these charts... (see "waveform chart_extra grid lines.JPG") Can you tell me why? thanks J Quote
hova2010 Posted October 19, 2009 Author Report Posted October 19, 2009 On 10/19/2009 at 7:03 PM, hova2010 said: 2 Questions Scott: 1) The 1st picture is from your VI ,"JH_waveform_graph_markers[1].vi I have circled the divisor, "60" in the picture. Should this number, 60, be changed based on whether Im using markers for minutes, hours, or days? I have the divisor set at "60" for my minute chart, "3600" for my hour interval chart and "86400" for my day interval chart Would these numbers be correct? (see "Waveform Chart Grid Markers.JPG") 2) Using "3600" for hour interval and "86400" for the week chart, Im getting "some extra grid markers" on these charts... (see "waveform chart_extra grid lines.JPG") Can you tell me why? thanks J My entire grid marker code is attached... Quote
smenjoulet Posted October 22, 2009 Report Posted October 22, 2009 On 10/19/2009 at 7:03 PM, hova2010 said: 1) The 1st picture is from your VI ,"JH_waveform_graph_markers[1].vi I have circled the divisor, "60" in the picture. Should this number, 60, be changed based on whether Im using markers for minutes, hours, or days? I have the divisor set at "60" for my minute chart, "3600" for my hour interval chart and "86400" for my day interval chart Would these numbers be correct? (see "Waveform Chart Grid Markers.JPG") 2) Using "3600" for hour interval and "86400" for the week chart, Im getting "some extra grid markers" on these charts... (see "waveform chart_extra grid lines.JPG") Can you tell me why? J, 1) Yes, those numbers are correct. 2) No, I really don't know why. I see it on the wavefrom graph as well. It is probably some minor bug or anomaly in the graph/chart drawing code. If it bothers you enough, turn off the minor grid for the x scale. The code looks correct. Remember, to keep gettting new markers you need to add to the list and take off the older markers. I can't really tell if that's what you're doing off to the right. -Scott Quote
ShaunR Posted October 22, 2009 Report Posted October 22, 2009 I knocked up a quick version of what I was talking about earlier about creating "views" of logged data. If you were to use it you would still need to figure out how to get "Month" data in properly and slide the scale (don't want to do all your work ) But should give you an idea. 1 Quote
ShaunR Posted October 23, 2009 Report Posted October 23, 2009 On 10/22/2009 at 8:22 PM, ShaunR said: I knocked up a quick version of what I was talking about earlier about creating "views" of logged data. If you were to use it you would still need to figure out how to get "Month" data in properly and slide the scale (don't want to do all your work ) But should give you an idea. Is anyone able to save this to a previous version other than 8.6 for the OP? Both LV x32 and x64 crash if I try to save below 8.6. Quote
smenjoulet Posted October 23, 2009 Report Posted October 23, 2009 On 10/23/2009 at 12:26 PM, ShaunR said: Is anyone able to save this to a previous version other than 8.6 for the OP? Both LV x32 and x64 crash if I try to save below 8.6. Nope. No luck. I even tried rewriting portions of it to see if could get it to save. Crashes every time. Sorry... Quote
asbo Posted October 23, 2009 Report Posted October 23, 2009 Victory! Logger 8.5.zipFetching info... 1 Quote
ShaunR Posted October 23, 2009 Report Posted October 23, 2009 (edited) On 10/23/2009 at 4:06 PM, smenjoulet said: Nope. No luck. I even tried rewriting portions of it to see if could get it to save. Crashes every time. Sorry... Me too. I even deleted bits until I had just an event case left.....still crashed when trying to save. On 10/23/2009 at 5:07 PM, asbo said: Victory! One point to the man with the magic digits. The secret? Edited October 23, 2009 by ShaunR Quote
asbo Posted October 23, 2009 Report Posted October 23, 2009 On 10/23/2009 at 5:26 PM, ShaunR said: One point to the man with the magic digits. The secret? I'm inclined to say, "I'm just that good" but I didn't do anything special. I wonder why my 8.6 install is so much more friendly than yours ... Quote
ShaunR Posted October 23, 2009 Report Posted October 23, 2009 On 10/23/2009 at 5:51 PM, asbo said: I'm inclined to say, "I'm just that good" but I didn't do anything special. I wonder why my 8.6 install is so much more friendly than yours ... Aha. Because mine isn't 8.6 its 2009. BUG! Quote
