Digital Input
Raihana
My Project is dealing with digital data from microcontroller. i need to input this to LABVIEW (version 8.2) via NI PCI-6221 DAQ card .
i have connected it to Port 0.0 - Port 0.3 and grounded the rest of the port pins on the DAQ card.
How can i read four data lines inputs and display it as decimal data on LABVIEW?
I have attached a picture of my LABVIEw set up.
Please answer!
1.doc
[...] I have attached a picture of my LABVIEw set up. [...]
I'm afraid of opening Word documents...  :( Please put a raster image in another post.
Have you tried using the DAQ Assistant?
Please answer!
The data coming out of your DAQ Assistant VI is an array. When you branch that wire to 3 different indicators, you just make 3 copies of the same data. You could either delete 2 of the array indicators and expand the front panel indicator of the 3rd to display all 3 data points. Or you could use an index array or something to separate the 3 data points if you wanted to display them individually.
Also, you do not need the sequence structure wrapped around the indicator.
Edited by Daryl
