vugie Posted December 4, 2009 Report Posted December 4, 2009 Name: Label Manager Submitter: vugie Submitted: 05 Dec 2009 File Updated: 23 Dec 2010 Category: JKI Right-Click Framework Plugins Version: 1.0.0 LabVIEW Version: 8.2 License Type: BSD (Most common) Label Manager (RCF Plugin) Copyright © 2009, Wojciech Golebiowski All rights reserved. Author: Wojciech Golebiowski (w_golebiowski (at) tlen.pl) Name: Label Manager Type: Right Click Framework Plugin LabVIEW version: 8.2.1 Description: Label Manager is Right-Click-Framework plugin for quick and ergonomic management of text labels styles. Styles are defined as text properties combined with alignment against label owning objects. They may be applied to any text label at block diagram or front panel, also with multiple selection. Once style is set to the label, the assignment is being remembered and may be updated on any change. Installation Preferably install VIP package with VI Package Manager Alternatively you may download ZIP and extract Label Manager folder to <LabVIEW Folder>\resource\JKI\RCF\Plugins\ and restart RCF Dependencies: OpenG Variant Config JKI State Machine Functionality - Generate label style from selection (retrieves both text attributes and alignment to label owning object if any) - Apply any style to currently selected text labels (also finding labels belonging to selected objects and showing up hidden labels) - Labels remember their style - when any of text attributes or label relative position has changed, original style may be recovered with single click (even after closing VI and opening it again). This association may be also removed. - Works for both Block Diagram and Front Panel labels - Graphically manage label styles Not-so-short video Support: If you have any problems with this code or want to suggest features: http://lavag.org/ind...showtopic=11583 Version History: 1.0.0: Initial release of the code. License (BSD): Copyright © 2009 Wojciech Golebiowski All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met: 1. Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer. 2. Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution. 3. The name of the author may not be used to endorse or promote products derived from this software without specific prior written permission. THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. Click here to download this file 2 Quote
Mark Balla Posted December 7, 2009 Report Posted December 7, 2009 Approved 12-6-09 and moved to the LabVIEW API > JKI Right-Click Framework Plugins catagory. Quote
vugie Posted December 15, 2009 Author Report Posted December 15, 2009 The name is editable in the listbox. Just like changing file names in Explorer - click on the new style to select it and after a while click again and the name becomes highlighted to edit (as opposed to item selection highlighting). I agree, it is not too intuitive... Any idea how it should look like? Quote
SuperS_5 Posted December 19, 2010 Report Posted December 19, 2010 While I was trying this out, I realized that the download is a zip and not a VIPM package. I made a VIPM package, using your readme documenation. Should I upload it here, or did you have some reason for not making a VIPM package? Quote
vugie Posted December 19, 2010 Author Report Posted December 19, 2010 While I was trying this out, I realized that the download is a zip and not a VIPM package. I made a VIPM package, using your readme documenation. Should I upload it here, or did you have some reason for not making a VIPM package? The only reason is that it was submitted in pre VIPM 2010 age. Please just send me the package and I'll add it to download. And thanks for the effort. Quote
vugie Posted December 23, 2010 Author Report Posted December 23, 2010 I uploaded a VIPM package and updated naming convention for ZIP Quote
