Rammer Posted February 7, 2010 Report Posted February 7, 2010 Has anyone used the Endevo Toolkit with LabVIEW 64 bit? LabVIEW always hangs when loading plugins and I suspect the endevo addon is the problem since it started happening more after that. Here is a picture of the error Quote
MikaelH Posted February 7, 2010 Report Posted February 7, 2010 Yes I have use it a bit, but your right LabVIEW does hang if any VIs aren't Pre-Compiled. So to solve this, you hav e to: 1) After installing GDS, move the 3 ini files in the folder: LabVIEW 2009\resource\Framework\Providers\Endevo 2) Make all VIs in this folder Writable (Not Read-Only) 3) Also make sure these folders are also Writable: \project and vi.lib\addons 4) Start LabVIEW and Masscompile all files in these 3 locations. 5) Just to be sure I would open all VIs direct under the folder: LabVIEW 2009\resource\Framework\Providers\Endevo, and verify that they really don't have a * in the title bar. ANd is so resave all when closing. 6) Quit LabVIEW 7) Move the 3 ini files back and restart LabVIEW Let me know how it went. I do have a beta GDS-version, that might work better, let me know if you want to try that one. //Mikael Quote
Rammer Posted February 8, 2010 Author Report Posted February 8, 2010 Hi Mikael, Once it starts to hang it always hangs - is there a way out or do I have to completely reinstall? Quote
MikaelH Posted February 8, 2010 Report Posted February 8, 2010 Just make sure you remove the 3 ini files, and LV should start as normal. Quote
Rammer Posted February 8, 2010 Author Report Posted February 8, 2010 It worked once. THen when LV launched a second time same error. Always works if .ini files are moved. Quote
MikaelH Posted February 8, 2010 Report Posted February 8, 2010 If you remove the INI files, LV will not load the GDS in memory. If GDS should be loaded, all files have to be compiled, if any file needs to be compiled (or LabVIEW thinks it need to be recompiled), LV will crash. I have only tested it once myself and I got it working at least once, but I'll look into this issue. Cheers, Mikael Quote
Rammer Posted June 18, 2010 Author Report Posted June 18, 2010 Mikael, Any update on more robust support for 64 bit? John Quote
Rammer Posted December 23, 2010 Author Report Posted December 23, 2010 Mikael, I tried downloading the GOOP 4.0 LabVIEW 64 Zip file and windows keeps saying the zip file is empty. Is there an FTP site or some other way to get this? John Quote
asbo Posted December 23, 2010 Report Posted December 23, 2010 I tried downloading the GOOP 4.0 LabVIEW 64 Zip file and windows keeps saying the zip file is empty. Is there an FTP site or some other way to get this? Works for me. Either its been fixed or you should try a different browser, perhaps. If the file is significantly less than the expected size (44.7MB), open it up in a text editor and see if you're actually getting a 404 or something like that. If it is the right size, try a different archive utility; I'm using 7zip. Quote
MikaelH Posted December 24, 2010 Report Posted December 24, 2010 Mikael, I tried downloading the GOOP 4.0 LabVIEW 64 Zip file and windows keeps saying the zip file is empty. Is there an FTP site or some other way to get this? John Hi John, and Merry Christmas. I have the same problem when I'm IE, but I always download larger files using Google Chrome, and that works always. We're trying to get it working with VIPM, but we still have some issues there. Cheers, Mikael Quote
