dblk22vball Posted April 7, 2010 Report Share Posted April 7, 2010 I am trying to emulate the function of a checkbox that you would find in most installers and other applications. With the checkbox that comes with labview, you have to check the checkbox to get it to "check". But in most other applications, if you click the label of that checkbox or the checkbox itself, it will check the box. I have not found a setting that lets you change this natively in labview. Should I put a hidden control under the label and have it check the box or is there another way to handle it? Thanks Quote Link to comment
Darren Posted April 7, 2010 Report Share Posted April 7, 2010 Show the Boolean Text of the checkbox instead of the Label. This will give you the behavior you're looking for. -D 2 Quote Link to comment
dblk22vball Posted April 7, 2010 Author Report Share Posted April 7, 2010 too simple, haha. worked great, thanks Quote Link to comment
Daklu Posted April 7, 2010 Report Share Posted April 7, 2010 Show the Boolean Text of the checkbox instead of the Label. This will give you the behavior you're looking for. I did not know that. Kudo for you! Quote Link to comment
Darren Posted April 7, 2010 Report Share Posted April 7, 2010 Should I post this as a weekly nugget? I assumed it was well-known, but if two LAVA guys didn't know about it, that probably translates to way more 'regular' LV programmers not knowing... -D Quote Link to comment
dblk22vball Posted April 7, 2010 Author Report Share Posted April 7, 2010 (edited) Should I post this as a weekly nugget? I assumed it was well-known, but if two LAVA guys didn't know about it, that probably translates to way more 'regular' LV programmers not knowing... -D Might not be a bad idea. Thanks:thumbup1: Edited April 7, 2010 by dblk22vball Quote Link to comment
Daklu Posted April 7, 2010 Report Share Posted April 7, 2010 Should I post this as a weekly nugget? I assumed it was well-known, but if two LAVA guys didn't know about it, that probably translates to way more 'regular' LV programmers not knowing... Couldn't hurt. Maybe it is well known... just 'cause I'm vocal on LAVA doesn't mean I know what I'm talking about! (It's awfully presumptuous to assume I'm a "guy." I could be the cutie on the left in my avatar picture you know. ) Quote Link to comment
PaulG. Posted April 7, 2010 Report Share Posted April 7, 2010 Should I post this as a weekly nugget? I assumed it was well-known, but if two LAVA guys didn't know about it, that probably translates to way more 'regular' LV programmers not knowing... -D Quote Link to comment
asbo Posted April 7, 2010 Report Share Posted April 7, 2010 Should I post this as a weekly nugget? I assumed it was well-known, but if two LAVA guys didn't know about it, that probably translates to way more 'regular' LV programmers not knowing... It's certainly not something I'd put down as obvious, and I don't any mention of the function in the help file (LV2009), so, yeah, it'd be a good nugget. It would almost be better if a checkbox hid its label by default and only showed the boolean text when dropped. Quote Link to comment
crelf Posted April 8, 2010 Report Share Posted April 8, 2010 Should I post this as a weekly nugget? I assumed it was well-known, but if two LAVA guys didn't know about it, that probably translates to way more 'regular' LV programmers not knowing... Yep - I didn't know about it. Quote Link to comment
smenjoulet Posted April 8, 2010 Report Share Posted April 8, 2010 Yep - I didn't know about it. WOW! And here I thought it was common knowledge. Incidentally, this is true of any button if you release the BooleanText and move it off the button. Clicking the text will still activate the button. I wouldn't advocate moving text off the button as standard procedure for anything other than Check Boxes or Radio Buttons, though. So does everyone know about shift-enter and ctrl-shift-enter on case structures? 1 Quote Link to comment
asbo Posted April 8, 2010 Report Share Posted April 8, 2010 So does everyone know about shift-enter and ctrl-shift-enter on case structures? Doesn't seem to do anything for me (LV2009) ... Quote Link to comment
smenjoulet Posted April 8, 2010 Report Share Posted April 8, 2010 Doesn't seem to do anything for me (LV2009) ... I guess this would make a good nugget as well (if it hasn't already been covered). Allow me to explain. If you are editing the case name in the case selector with the text tool: Shift-Enter will give you a new blank case. Ctrl-Shift-Enter will give you a duplicate of the case you were on. In both methods, the new case becomes the active displayed case with the text tool active in the case selector. Type a new name and hit the key combo again. You can rapidly prototype up a bunch of empty or duplicated cases. 2 Quote Link to comment
Cat Posted April 8, 2010 Report Share Posted April 8, 2010 Shift-Enter will give you a new blank case. Ctrl-Shift-Enter will give you a duplicate of the case you were on. Maybe it's just me, but wouldn't it be just as easy to right-click on the case structure and select "Add Case After" or "Duplicate Case"?? I must be missing something here... Quote Link to comment
smenjoulet Posted April 8, 2010 Report Share Posted April 8, 2010 Maybe it's just me, but wouldn't it be just as easy to right-click on the case structure and select "Add Case After" or "Duplicate Case"?? I must be missing something here... Absolutely if you aren't already typing a case name in the selector and you only want to add 1 case. But what if you want to add 5 cases... or 10? I guarantee you when you need to do that it is much faster than switching back and forth between mouse and keyboard, right-clicking, selecting, etc... The key is that you can do it over and over again while typing your case names. Quote Link to comment
asbo Posted April 8, 2010 Report Share Posted April 8, 2010 In a temporary moment of clarity, I have realized I was pressing CTRL+Shift. Cool tip! Quote Link to comment
Rolf Kalbermatter Posted April 8, 2010 Report Share Posted April 8, 2010 So does everyone know about shift-enter and ctrl-shift-enter on case structures? Didn't know that either but it makes sense, as it is in fact almost the same with ring controls and enums. Quote Link to comment
