SdKfz10 Posted April 11, 2010 Report Posted April 11, 2010 Are there any example code around showing how to do a QSM with variant data (Cluster of event+command), where event = strictly typed enum and command=string. I guess there was some on the old LAVA-forum, but now I can't find any examples here. (LabVIEW 7.1.1) Quote
jgcode Posted April 12, 2010 Report Posted April 12, 2010 On 4/11/2010 at 4:34 PM, SdKfz10 said: Are there any example code around showing how to do a QSM with variant data (Cluster of event+command), where event = strictly typed enum and command=string. I guess there was some on the old LAVA-forum, but now I can't find any examples here. (LabVIEW 7.1.1) Here is a good article on implementing a QSM, it is from the Expression Flow website. I am not sure what version the example download is in, but you should be able to easily replicate it from the article. Quote
Francois Normandin Posted April 12, 2010 Report Posted April 12, 2010 On 4/12/2010 at 12:18 AM, jgcode said: Here is a good article on implementing a QSM, it is from the Expression Flow website. I am not sure what version the example download is in, but you should be able to easily replicate it from the article. Link is broken because of weird bug with links that contain "expression": Here is the unlinked path: "expressionflow.com/2007/10/01/labview-queued-state-machine-architecture" (BTW, that's an excellent tutorial to keep at hand for newbies.) Quote
jgcode Posted April 12, 2010 Report Posted April 12, 2010 On 4/12/2010 at 2:01 AM, François Normandin said: Link is broken because of weird bug with links that contain "expression": Here is the unlinked path: "expressionflow.com/2007/10/01/labview-queued-state-machine-architecture" (BTW, that's an excellent tutorial to keep at hand for newbies.) That is weird! I am assuming it is an IP Board Bug? Does anyone know if this been reported? Quote
Francois Normandin Posted April 12, 2010 Report Posted April 12, 2010 On 4/12/2010 at 3:18 AM, jgcode said: That is weird! I am assuming it is an IP Board Bug? Does anyone know if this been reported? It's an IP Board issue. I think Tomi Malla noticed it first on his own posts... Quote
Michael Aivaliotis Posted April 12, 2010 Report Posted April 12, 2010 On 4/12/2010 at 3:32 AM, François Normandin said: It's an IP Board issue. I think Tomi Malla noticed it first on his own posts... Yes, Known Issue: Quote
