lovemachinez Posted May 20, 2010 Report Posted May 20, 2010 Dear, all I have 2 similar webcam plugin with my laptop and want to snap picture from them.(not same time) The problem is these two camera have same name, so when I want to select and capture with the 2nd webcam, LV always return to capture with the first webcam. How would I do? Can I change driver's name of the webcam? best regards Quote
Bjarne Joergensen Posted September 27, 2012 Report Posted September 27, 2012 Hi Lovemachinez I got the same question. Did you ever find a solution? thanks in advance Bjarne Quote
crelf Posted September 27, 2012 Report Posted September 27, 2012 You can change their names in MAX (Measurement & Automation Explorer). Go to "Devices and Interfaces", then "IMAQdx" (this might take a few seconds to show up as it scans for cameras), then your cameras should be listed - you can right click on them to rename them there. Quote
drjdpowell Posted September 27, 2012 Report Posted September 27, 2012 Had that problem. I believe it is because the Windows software was never made to work with multiple cameras at once. Each identical camera is listed in the Windows Registry under identical names. I believe you can modify the registry, but that is not a satisfactory solution. Quote
crelf Posted September 27, 2012 Report Posted September 27, 2012 Had that problem. I believe it is because the Windows software was never made to work with multiple cameras at once. Each identical camera is listed in the Windows Registry under identical names. I believe you can modify the registry, but that is not a satisfactory solution. Really? I've got it working just fine on my PC. I wonder: are you using NI-IMAQdx? Or something different? Quote
drjdpowell Posted September 27, 2012 Report Posted September 27, 2012 Really? I've got it working just fine on my PC. I wonder: are you using NI-IMAQdx? Or something different? I think I’ve seen it with NI-IMAQdx. It’s only with some USB cameras, such as webcams. And it is only when using identical models; one can use multiple cameras of different models, because they go into the Registry under their model names. Quote
crelf Posted September 27, 2012 Report Posted September 27, 2012 I think I’ve seen it with NI-IMAQdx. It’s only with some USB cameras, such as webcams. And it is only when using identical models; one can use multiple cameras of different models, because they go into the Registry under their model names. If you're using IMAQdx, it uses the names listed in MAX, not the registry, so this shouldn't be an issue. Quote
drjdpowell Posted September 27, 2012 Report Posted September 27, 2012 Cameras showed up in MAX no problem, but both MAX names would, if selected, lead to images from only one of the cameras. It’s was driver issue, at a lower level than MAX. Quote
crelf Posted October 2, 2012 Report Posted October 2, 2012 Cameras showed up in MAX no problem, but both MAX names would, if selected, lead to images from only one of the cameras. It’s was driver issue, at a lower level than MAX. Ugh - that's ugly. Quote
