mandya14 Posted May 23, 2010 Report Posted May 23, 2010 I have downloaded all the iDAQUSB Hytek drivers and vi's and even tested the idaqtest&log. I have created my own vi where i read continuously Data from digital DIO(channel 9-16) and save them successfully in my database. I have a micro controller-encoder-transmitter and on the other side a receiver-decoder-Hytek-PC The micro-controller is sending a 255 header followed by 14 bytes each for a different sensor. The problem i am facing is that i need a some sort of trigger to only read when change of state so that the one byte don't overwrite the other. in my case my hytek is reading 255-255 for all my data. I need it to read only when it s triggered so i don t have overwrite. Can i use the trigger input for digital input as well?? i was thinking about connecting the trigger input to the vt(trigger) of the receiver. but i dunno if it will work on labview. I am enumerating...opening session...read/write IO and closing the devices each time. but i need it to read each time i send a new byte. how can i do that? i would appreciate any help.thank you Quote
Irene_he Posted June 3, 2010 Report Posted June 3, 2010 Dear Mandy, Sorry to reply this late. As I understand that you only use DIO 9-16 for your byte reading. Although you can't use the trigger line for analog inputs for DIO ports, but you can make use the DIO ports from 1-8, check one of them to see the change of state, then read/keep the DIO9-16 states. Hope this will work for your case. Kind Regards, Irene Quote
kamranmu Posted August 13, 2020 Report Posted August 13, 2020 Dear Irene_he Hope you are doing well, I have the iUSBDAQ Module U120816, but lost its software/ Driver CD. Please help me in this regard, because the company website is down since a long. Quote
georgechen1972 Posted May 12, 2023 Report Posted May 12, 2023 On 8/13/2020 at 11:55 AM, kamranmu said: Dear Irene_he Hope you are doing well, I have the iUSBDAQ Module U120816, but lost its software/ Driver CD. Please help me in this regard, because the company website is down since a long. Quote
georgechen1972 Posted May 13, 2023 Report Posted May 13, 2023 Hi, Did anyone still keep DAQ U120816 driver files? Please kindly to share to me. georgechen1972@gmail.com Great thanks Quote
Gribo Posted May 15, 2023 Report Posted May 15, 2023 Here is the link: USB Acquisitions Model – JaSSC Inc (jassc-inc.com) You will have to contact the company for support and drivers. Quote
