Mark Balla Posted September 16, 2010 Report Posted September 16, 2010 Here is what I have so far. I took the calculations and put them in a JKI state machine. I also added the menu functions you asked for. I will try and add the graph annotation and comment on the look of the curves in a later post. Version 3 9-16-2010.zipFetching info... Quote
Guest Avinashgogineni Posted September 16, 2010 Report Posted September 16, 2010 On 9/16/2010 at 12:43 PM, Mark Balla said: Here is what I have so far. I took the calculations and put them in a JKI state machine. I also added the menu functions you asked for. I will try and add the graph annotation and comment on the look of the curves in a later post. Version 3 9-16-2010.zipFetching info... Hello Mark, Thanks for your response. I have seen that still I am getting the same rectangular base at the bottom. Could you please check it once. I just want to bring this to your notice. So, I am attaching the file in which I planned to get the output Quote
Guest Avinashgogineni Posted September 20, 2010 Report Posted September 20, 2010 On 9/16/2010 at 12:43 PM, Mark Balla said: Here is what I have so far. I took the calculations and put them in a JKI state machine. I also added the menu functions you asked for. I will try and add the graph annotation and comment on the look of the curves in a later post. Version 3 9-16-2010.zipFetching info... Mark, can I get that VI soon by today or tomorrow? Quote
Guest Avinashgogineni Posted September 24, 2010 Report Posted September 24, 2010 On 9/16/2010 at 12:43 PM, Mark Balla said: Here is what I have so far. I took the calculations and put them in a JKI state machine. I also added the menu functions you asked for. I will try and add the graph annotation and comment on the look of the curves in a later post. Version 3 9-16-2010.zipFetching info... Hello Mark have you seen my posts? could you please help me in that? are you still busy? Quote
Mark Balla Posted September 24, 2010 Report Posted September 24, 2010 I'm back. I only have access to LAVA via my phone so this will be short. The sharp edge is due to the fact that all data below the threshold is set to the same value. This is what makes the data flat or smooth. What is the reason to round the sharp corners when the smooth data has no meaning. I thought you only cared about the peaks. Have you changed your mind and do you now want to go back to an average or mean of the data below the threshold? Quote
Guest Avinashgogineni Posted September 25, 2010 Report Posted September 25, 2010 On 9/24/2010 at 6:02 PM, Mark Balla said: I'm back. I only have access to LAVA via my phone so this will be short. The sharp edge is due to the fact that all data below the threshold is set to the same value. This is what makes the data flat or smooth. What is the reason to round the sharp corners when the smooth data has no meaning. I thought you only cared about the peaks. Have you changed your mind and do you now want to go back to an average or mean of the data below the threshold? Hello Mark I tried this thing see here, Export new is the main file , which i have done see it once. After seeing that results I cam to know that thing, Even peaks may vary. It doesn't matter, but i need have that tool tip in my VI. When ever i keep my cursor near to the peak, it should give the peak number and Coordinates of X and Y. Here tool tip should have button in the VI. If we click on that and then that function starts working. If it is not clear please look at my previous post you can understand better or else I will explain indetailed again On 9/25/2010 at 5:15 AM, Avinashgogineni said: Hello Mark I tried this thing see here, Export new is the main file , which i have done see it once. After seeing that results I cam to know that thing, Even peaks may vary. It doesn't matter, but i need have that tool tip in my VI. When ever i keep my cursor near to the peak, it should give the peak number and Coordinates of X and Y. Here tool tip should have button in the VI. If we click on that and then that function starts working. If it is not clear please look at my previous post you can understand better or else I will explain indetailed again Here is my see export new. Its the main one, which I designed Version 2.1 9-4-2010.zipFetching info... Quote
Mark Balla Posted September 25, 2010 Report Posted September 25, 2010 On 9/25/2010 at 5:22 AM, Avinashgogineni said: Hello Mark I tried this thing see here, Export new is the main file , which i have done see it once. After seeing that results I cam to know that thing, Even peaks may vary. It doesn't matter, I do not understand what you want me to do here so I will leave the calculation the same as before. On 9/25/2010 at 5:22 AM, Avinashgogineni said: but i need have that tool tip in my VI. When ever i keep my cursor near to the peak, it should give the peak number and Coordinates of X and Y. Here tool tip should have button in the VI. If we click on that and then that function starts working. If it is not clear please look at my previous post you can understand better or else I will explain indetailed again I've added two new features to this code. 1: The peak and valley arrays are combined with time so each peak point you can see the value and time in the array. 2: I have added cursors to each of the graphs. This will allow you to drag the cursor around to any point you wish. To use the cursor select the cursor tool (see below) right click on the cursor and select bring to center Place your mouse over the cursor line until you see the double arrow Move the cursor to where you want. and the value and time will show in the cursor box If you want to move the cursor one point at a time click on the square arrow buttons Version 4 9-25-2010.zipFetching info... Quote
Guest Avinashgogineni Posted September 26, 2010 Report Posted September 26, 2010 On 9/25/2010 at 10:09 PM, Mark Balla said: I do not understand what you want me to do here so I will leave the calculation the same as before. I've added two new features to this code. 1: The peak and valley arrays are combined with time so each peak point you can see the value and time in the array. 2: I have added cursors to each of the graphs. This will allow you to drag the cursor around to any point you wish. To use the cursor select the cursor tool (see below) right click on the cursor and select bring to center Place your mouse over the cursor line until you see the double arrow Move the cursor to where you want. and the value and time will show in the cursor box If you want to move the cursor one point at a time click on the square arrow buttons Version 4 9-25-2010.zipFetching info... Hello Mark I am unable to open this file I am getting these errors. Could you please help me here? Quote
Mark Balla Posted September 26, 2010 Report Posted September 26, 2010 On 9/26/2010 at 3:10 AM, Avinashgogineni said: Hello Mark I am unable to open this file I am getting these errors. Could you please help me here? Sorry didn't do the source distribution correctly. Try this one Version 4.1 9-25-2010.zipFetching info... Quote
Guest Avinashgogineni Posted September 26, 2010 Report Posted September 26, 2010 On 9/26/2010 at 4:28 AM, Mark Balla said: Sorry didn't do the source distribution correctly. Try this one Version 4.1 9-25-2010.zipFetching info... Hello Mark, could you please modify these things here in my VI? why because Here we are not having the sharp edges in the bottom of the pulse and have the Export life function in this. So could you please modify this VI? Here If you observe, you can find the magnitude, it is the difference between peaks and valley. So, we should find the magnitudes of averaged and raw data in descending order and should tell that particular magnitude peak number. I will should the example here. peak4 : 4.156 Peak2: 3.12 Peak1: 1.156 Peak3: 0.148 In this file.. Export new is the main VI Version 2.1 9-4-2010.zipFetching info... Quote
Guest Avinashgogineni Posted September 27, 2010 Report Posted September 27, 2010 On 9/26/2010 at 5:56 PM, Avinashgogineni said: Hello Mark, could you please modify these things here in my VI? why because Here we are not having the sharp edges in the bottom of the pulse and have the Export life function in this. So could you please modify this VI? Here If you observe, you can find the magnitude, it is the difference between peaks and valley. So, we should find the magnitudes of averaged and raw data in descending order and should tell that particular magnitude peak number. I will should the example here. peak4 : 4.156 Peak2: 3.12 Peak1: 1.156 Peak3: 0.148 In this file.. Export new is the main VI Hello Mark could you please reply this post Quote
Mark Balla Posted September 28, 2010 Report Posted September 28, 2010 Do you want to go back to averaging all points? If you do how many points do we average together. How do we know this number? Quote
Guest Avinashgogineni Posted September 28, 2010 Report Posted September 28, 2010 On 9/28/2010 at 5:38 PM, Mark Balla said: Do you want to go back to averaging all points? If you do how many points do we average together. How do we know this number? Hello Mark we should average all the points. Quote
Mark Balla Posted September 28, 2010 Report Posted September 28, 2010 How many points do we average together. How do we know this number? Quote
Guest Avinashgogineni Posted September 29, 2010 Report Posted September 29, 2010 On 9/28/2010 at 11:05 PM, Mark Balla said: How many points do we average together. How do we know this number? Hello Mark I am attaching one file here. I think I can explain clearly with this example. Here The red line is our Averaged data and white line is the original data. Red line is sharp at the base. Actually My intention is to get the straight up to to 28.35000 and then it should give the original data up to 28.62. We need to get that slant curve for every pulse instead of that sharp thing. I am asking to get straight line up to 28.35, because we have to note down the Y axis reference value for calculating the magnitude ( It is the difference between the peak and the base of the pulse). Quote
Guest Avinashgogineni Posted October 1, 2010 Report Posted October 1, 2010 On 9/29/2010 at 4:00 PM, Avinashgogineni said: Hello Mark I am attaching one file here. I think I can explain clearly with this example. Here The red line is our Averaged data and white line is the original data. Red line is sharp at the base. Actually My intention is to get the straight up to to 28.35000 and then it should give the original data up to 28.62. We need to get that slant curve for every pulse instead of that sharp thing. I am asking to get straight line up to 28.35, because we have to note down the Y axis reference value for calculating the magnitude ( It is the difference between the peak and the base of the pulse). Hello Mark could you please reply for this? I waiting for your reply. Quote
Mark Balla Posted October 2, 2010 Report Posted October 2, 2010 Go back to our previous discussion here Download version 2 Then tell me if this is what you want. If yes then I will put the calculation in the new code. Quote
Guest Avinashgogineni Posted October 2, 2010 Report Posted October 2, 2010 On 10/2/2010 at 4:59 PM, Mark Balla said: Go back to our previous discussion here http://lavag.org/top...ect-on-labview/ Download version 2 Then tell me if this is what you want. If yes then I will put the calculation in the new code. Hello Mark, I am really sorry for confusing you. The file which I received last time from you is really good, except that sharp edges at the bottom. I am saying that I would like to have that straight line at the bottom to certain distance like if we are getting peak at 5. we should have that straight base line up to 3 and then it should give the original data pulse upto 7,and from 7 we need to get again a straight line at the base. We need to get this straight line only to find the magnitude of the pulse Which is the diffrence between the Peak and the base of the pulse. I am attaching a file here. Hope it will make you to better understand about that. Quote
Mark Balla Posted October 4, 2010 Report Posted October 4, 2010 I am unable to understand what it is you want. It sounds like you want to bring back averaging. So here is version 5 The program will average only the points below the threshold. The points above the threshold will not be changed. If you change the "A Points To Average" and "B Points To Average" numbers the graph will redraw. The bigger you make the numbers the flatter the curve will be. Version 5 10-3-2010.zipFetching info... Quote
Guest Avinashgogineni Posted October 4, 2010 Report Posted October 4, 2010 On 10/4/2010 at 3:54 AM, Mark Balla said: I am unable to understand what it is you want. It sounds like you want to bring back averaging. So here is version 5 The program will average only the points below the threshold. The points above the threshold will not be changed. If you change the "A Points To Average" and "B Points To Average" numbers the graph will redraw. The bigger you make the numbers the flatter the curve will be. Version 5 10-3-2010.zipFetching info... Hello Mark I am getting this error. Quote
Guest Avinashgogineni Posted October 4, 2010 Report Posted October 4, 2010 On 10/4/2010 at 2:18 PM, Avinashgogineni said: Hello Mark I am getting this error. Hello Mark, I pressed "CTRL +B" Now it's working good. But i am getting the same curve. I am not expecting the sarp corner at the base. I would like to have the flat base to get the Y coordinate corresponding to that. If we get that y cordinate, we can calculate the magnitude. magnitude is the difference between the peak and the base of the pulse. Quote
Mark Balla Posted October 4, 2010 Report Posted October 4, 2010 Try this one Version 5.1 10-4-2010.zipFetching info... Quote
Guest Avinashgogineni Posted October 4, 2010 Report Posted October 4, 2010 On 10/4/2010 at 5:26 PM, Mark Balla said: Try this one Hello Mark, Thank you so much. That's what I am looking for. Its working, really good. Now we should get the magnitudes of each pulse. Magnitude is the distance between the peak and the base line, both the values should be from y axis. just taking the difference between them. After getting those values, we should indicate the values referring to peak values in descending order. Quote
Guest Avinashgogineni Posted October 19, 2010 Report Posted October 19, 2010 On 10/4/2010 at 5:26 PM, Mark Balla said: Try this one Hello Mark. I designed the VI in some what better way. and I would like to make it a user friendly VI. I am attaching the copy of the file. Open the version5.2. verify the main file. In the second file, You can understand the way to design this VI. in that the numbers 1 2 3 4 5 6 7 8 9 ..... indicates the Channels number. If we have 9columns in our VI, 1 to 8 Numbers should be highlighted. If we press on 1 it should give the graph between first column and second column, If we press on 7 it should give the graph between first column and 8th column. If you have any doubts please respond to this post. Version 5.2 10-4-2010.zipFetching info... Quote
Mark Balla Posted October 22, 2010 Report Posted October 22, 2010 On 10/19/2010 at 4:48 PM, Avinashgogineni said: Hello Mark. I designed the VI in some what better way. and I would like to make it a user friendly VI. I am attaching the copy of the file. Open the version5.2. verify the main file. In the second file, You can understand the way to design this VI. in that the numbers 1 2 3 4 5 6 7 8 9 ..... indicates the Channels number. If we have 9columns in our VI, 1 to 8 Numbers should be highlighted. If we press on 1 it should give the graph between first column and second column, If we press on 7 it should give the graph between first column and 8th column. If you have any doubts please respond to this post. I can't review it because you have locked the block diagram. Please do not post code to LAVA with block diagrams locked. Quote
