CGMENG Posted July 10, 2010 Report Posted July 10, 2010 I'm having a problem with the .net MonthCalendar window in LV9 on Window 7. The RHS window is cut off. If I resize the window it returns to the default once the vi is run. I've tried changing the size from property nodes without success. Does anyone know of a resolution to this problem? Quote
j1balogh Posted December 29, 2010 Report Posted December 29, 2010 No, actually I am having the same issue. Quote
SuperS_5 Posted December 29, 2010 Report Posted December 29, 2010 Hi, I don't use .Net controls, so I could not find a permanent solution. The "contbounds" property node is settable while running and retains the chosen value until the VI finishes execution. Although I must be set every execution, it will at least be the right size while running. Quote
settles Posted March 2, 2011 Report Posted March 2, 2011 I also had the same issue. Apparently this has been identified as a bug in 2010 (http://forums.ni.com/t5/LabVIEW/MonthCalendar-window-cut-off-on-RHS/td-p/1176967). Quote
ShaunR Posted March 2, 2011 Report Posted March 2, 2011 I also had the same issue. Apparently this has been identified as a bug in 2010 (http://forums.ni.com...HS/td-p/1176967). Better make that 2009 too Quote
