Suvin Posted July 16, 2010 Report Share Posted July 16, 2010 Hi All, I want to create password for a zip/excel file programatically.Any ideas? Please help. Suvin Quote Link to comment
Yair Posted July 16, 2010 Report Share Posted July 16, 2010 ZIP and Excel files are two completely different things. For the Excel file, I assume the Save method provided by Excel has an optional password field. If not, you should search the Excel API to see how it's done. The ZIP file presumably depends on the library you use to save the ZIP file. If it exposes a method of password protecting the file, you can use that. If it does not, you'll need to find a library which does. OpenG has a ZIP library which might allow this. If it doesn't, you might be able to extend it yourself by calling the relevant functions from the DLL. Quote Link to comment
Phillip Brooks Posted July 16, 2010 Report Share Posted July 16, 2010 OpenG has a ZIP library which might allow this. If it doesn't, you might be able to extend it yourself by calling the relevant functions from the DLL. I can confirm that the OpenG ZIP library has password functionality, but I've never actually tested it. Considering that Rolf is the originator, I'm sure that this works flawlessly or he wouldn't have provided the interface on the VIs. ZLIB Store Quote Link to comment
Rolf Kalbermatter Posted December 13, 2010 Report Share Posted December 13, 2010 I can confirm that the OpenG ZIP library has password functionality, but I've never actually tested it. Considering that Rolf is the originator, I'm sure that this works flawlessly or he wouldn't have provided the interface on the VIs. ZLIB Store I did test it but didn't make extensive tests. It seemed to work for any combination of OpenG compress -> ALZIP / 7-ZIP uncompress and vice versa as well as compress and uncompress in OpenG. This was enough for me to provide the parameter on the VI interface. I can't exclude the possibility that the generated password might not be compatible with certain other ZIP utilities, and I have also stopped using ALZIP a year or so ago, since they were getting worse and worse in advertisement and eventually tried to push an upgrade to a once free version on the users that was only a trial version and had to be purchased to continue using. Quote Link to comment
