2D arrays
Hello!
I have 2 2-D numeric arrays. I need to do some math with each relative cells.
for example cell (0,0) of both arrays, until cell (8,8).
How can I get the value of the cells?
Thanks for any help,
Miri
try.vi
Yes, As you can see in try.vi I use the subset function.
My inputs should be two 2D arrays 8X8. And Array3 like I understand should be the merge of them.
I think the first problem is somewhere here - What kind of array - array3 should be in that case?
Thanks
What exactly do you mean by "merge"? Are you looking for a 3D array or a concatenation? It really depends on what the data is and what you are doing with it (post processing algorithms, save to disk, etc.).
The Data is positive numbers (0-3000).
I have two arrays 8X8 with that data.
I need to subtract,add,divide same cells in both arrays.
Hi Miri
The LabVIEW math operators are polymorphic meaning they accept different datatypes.
You can actually just wire the 2D Numeric Arrays straight to them and you will be doing that maths operation on the same cell in each array.
The result will be a 2D Numeric Array.
Two flavors:
post-10325-061605600 1280223142_thumb.pn
