NelsonUWP Posted July 28, 2010 Report Posted July 28, 2010 Hey guys, I'm trying to make some modifications to the project explorer menu items, specifically when you right-click on an item (e.g. Right-click -> Make VI a Template, bad example but you get the picture). Is there a way to modify these (and other) menu items in LabVIEW; and more importantly that modify, make them usable? Thanks, Adam Quote
Francois Normandin Posted July 28, 2010 Report Posted July 28, 2010 Hey guys, I'm trying to make some modifications to the project explorer menu items, specifically when you right-click on an item (e.g. Right-click -> Make VI a Template, bad example but you get the picture). Is there a way to modify these (and other) menu items in LabVIEW; and more importantly that modify, make them usable? Thanks, Adam As of today, I know only of the Right-Click Framework from JKI to do that in the development environment. Don't know if NI plans something for the future. It's been a feature request for some time now. The RCF certainly does the job and you can customize it to your will. Quote
NelsonUWP Posted July 28, 2010 Author Report Posted July 28, 2010 As of today, I know only of the Right-Click Framework from JKI to do that in the development environment. Don't know if NI plans something for the future. It's been a feature request for some time now. The RCF certainly does the job and you can customize it to your will. The RCF had to be built somehow. But, more-so, I'm looking more for a way to interact with the LabVIEW menus; right-click was the way to bring up the menu. Quote
jgcode Posted July 28, 2010 Report Posted July 28, 2010 Two companies I know of thus far, have LabVIEW Project integration as part of their products. There is a way (maybe still in beta?), but its definately not public. Quote
NelsonUWP Posted July 30, 2010 Author Report Posted July 30, 2010 Two companies I know of thus far, have LabVIEW Project integration as part of their products. There is a way (maybe still in beta?), but its definately not public. I've seen this. In fact, I've gone so far as to put my registry export AND the entire C:\program files\NI folder under source control, install updates and then check for changes, no luck. It has to be possible. Quote
NelsonUWP Posted July 30, 2010 Author Report Posted July 30, 2010 Alright, I figured it out if anyone is interested. You just have to create a VI, "Action.vi" and a text file "Action.txt" and drop it in the "project" folder if you want it put there. The display of the menu item is just the contents of the txt file. If you want to create a sub-menu, just create a folder and follow the same directions as above. Quote
Francois Normandin Posted July 30, 2010 Report Posted July 30, 2010 Alright, I figured it out if anyone is interested. You just have to create a VI, "Action.vi" and a text file "Action.txt" and drop it in the "project" folder if you want it put there. The display of the menu item is just the contents of the txt file. If you want to create a sub-menu, just create a folder and follow the same directions as above. specifically when you right-click on an item Sorry I didn't understand what you meant. I was under the impression you wanted to edit the LabVIEW right -click menus just like it was a .mnu file. You can do the same as you stated above for other menus too (File, Help & Tools). See the wiki page here. Quote
NelsonUWP Posted July 30, 2010 Author Report Posted July 30, 2010 (edited) Sorry I didn't understand what you meant. I was under the impression you wanted to edit the LabVIEW menus just like it was a .mnu file. You can do the same as you stated above for other menus too (File, Help & Tools). See the wiki page here. There's also this http://decibel.ni.co...t/docs/DOC-8496 Edit: stupid fonts Sorry I didn't understand what you meant. I was under the impression you wanted to edit the LabVIEW right -click menus just like it was a .mnu file. You can do the same as you stated above for other menus too (File, Help & Tools). See the wiki page here. François, Ah, sorry, didn't see your second quote. I guess I'm still looking for that, I figured one would lead to the other, but I don't think that's the case. I was looking to integrate a dev tool into the project explorer when you right-click on a VI. Edited July 30, 2010 by NelsonUWP Quote
Francois Normandin Posted July 30, 2010 Report Posted July 30, 2010 There was a blog entry by Darren in early 2009 about this. I haven't seen any comments about LV2010 having this available. Anyone has had time to browse enough in 2010 to let us know? Quote
NelsonUWP Posted July 30, 2010 Author Report Posted July 30, 2010 I think that was before the right-click framework was available from JKI. Also 2010 doesn't have this feature AFAIK. Quote
jgcode Posted July 30, 2010 Report Posted July 30, 2010 I'm trying to make some modifications to the project explorer menu items, specifically when you right-click on an item (e.g. Right-click -> Make VI a Template, bad example but you get the picture). Is there a way to modify these (and other) menu items in LabVIEW; and more importantly that modify, make them usable? Alright, I figured it out if anyone is interested. You just have to create a VI, "Action.vi" and a text file "Action.txt" and drop it in the "project" folder if you want it put there. The display of the menu item is just the contents of the txt file. If you want to create a sub-menu, just create a folder and follow the same directions as above. The 'Project' folder (<LabVIEW>\project) relates to the Tools menu, not to integration with items in the LabVIEW Project Explorer. Or am I missing something? Quote
NelsonUWP Posted July 30, 2010 Author Report Posted July 30, 2010 The 'Project' folder (<LabVIEW>\project) relates to the Tools menu, not to integration with items in the LabVIEW Project Explorer. Or am I missing something? No, you are correct. It was a 2 part question. 1) LabVIEW dev env. menus. Check and 2) Project Explorer context menus. Uncheck Quote
