Why Child class cannot read its own values?
Class A ->
Private Data: Q Ref and Cluster-A
Protected Member function: “Initialize” which is a dynamic dispatch, Creates a Queue and assign user defined values to Cluster-A
Private Member function: “Start Write” which calls “Write Information” every xx interval of times
Public Member function: “Write Information” which is a dynamic dispatch
Class B -> Inherits from Class A
Private Data: Cluster-B
Protected Member function: “Initialize” which is a dynamic dispatch, first calls the Parent Initialize and then assigns the User define value to Cluster-B
Class C -> Inherits from Class B
Private Data: A Numeric Control (default = -1) and a Boolean Control (default = False)
Protected Member function: “Initialize” which is a dynamic dispatch, pass the user defined values of Cluster-A and Cluster-B to Parent Class
1. Write Information – Write the information from Queue to the file depending on the Numeric control, Boolean Control and Cluster-B data of Class B
2. Create - creates an object of class C + Calls Initialize to pass data to respective class
3. Set # – Assign the user defined value to Numeric Control
4. Read # – Read the value of Numeric Control
5. Set Bool – Assign the user define value to Boolean Control
6. Read Bool – Return the value of Boolean Control
Class D -> Inherits from Class B
Private Data: Empty
1. Write Information – Write the information from Queue to the file depending on the Cluster-B data of Class B
2. Create - creates an object of class D + Calls Initialize to pass data to respective class
My application,
Create Object C + Set # (to say 10) and
Create Object D
Object D - Write Information works fine
Object C - Write Information has Read # and Read Bool which always returns the default value.
Not able to understand why?
Any help is appreciated.
Thanks.
Edited by Vidula S
