V_T_S Posted July 28, 2010 Report Share Posted July 28, 2010 (edited) Class A -> Private Data: Q Ref and Cluster-A Protected Member function: “Initialize” which is a dynamic dispatch, Creates a Queue and assign user defined values to Cluster-A Private Member function: “Start Write” which calls “Write Information” every xx interval of times Public Member function: “Write Information” which is a dynamic dispatch Class B -> Inherits from Class A Private Data: Cluster-B Protected Member function: “Initialize” which is a dynamic dispatch, first calls the Parent Initialize and then assigns the User define value to Cluster-B Public Member function: “Write Information” which is a dynamic dispatch Class C -> Inherits from Class B Private Data: A Numeric Control (default = -1) and a Boolean Control (default = False) Protected Member function: “Initialize” which is a dynamic dispatch, pass the user defined values of Cluster-A and Cluster-B to Parent Class Public Member function: 1. Write Information – Write the information from Queue to the file depending on the Numeric control, Boolean Control and Cluster-B data of Class B 2. Create - creates an object of class C + Calls Initialize to pass data to respective class 3. Set # – Assign the user defined value to Numeric Control 4. Read # – Read the value of Numeric Control 5. Set Bool – Assign the user define value to Boolean Control 6. Read Bool – Return the value of Boolean Control Class D -> Inherits from Class B Private Data: Empty Protected Member function: “Initialize” which is a dynamic dispatch, pass the user defined values of Cluster-A and Cluster-B to Parent Class Public Member function: 1. Write Information – Write the information from Queue to the file depending on the Cluster-B data of Class B 2. Create - creates an object of class D + Calls Initialize to pass data to respective class My application, Create Object C + Set # (to say 10) and Create Object D Object D - Write Information works fine Object C - Write Information has Read # and Read Bool which always returns the default value. Not able to understand why? Any help is appreciated. Thanks. Edited July 28, 2010 by Vidula S Link to comment
Yair Posted July 29, 2010 Report Share Posted July 29, 2010 Post the code. It's a lot easier than following all that text. Link to comment
Aristos Queue Posted August 2, 2010 Report Share Posted August 2, 2010 I tried to puzzle it out from your text description, but I couldn't get a good grasp on the situation. If you can post VIs, that would help a lot. Link to comment
V_T_S Posted August 4, 2010 Author Report Share Posted August 4, 2010 I tried to puzzle it out from your text description, but I couldn't get a good grasp on the situation. If you can post VIs, that would help a lot. All I needed was reference class. I found the solution in examples. Thanks! Link to comment
Please sign in to comment
Sign In Now
