why the debug buttons are missing?
I am very curious that i can't debug the below Labview 8.6 built-in examples:
TCP Communicator - Active.vi
TCP Communicator - Passive.vi
Anybody know how to resolve this?
very appreciate your help!!!
Open the VI properties (by hitting CTRL + i) go to the "Execution" section and tick the option "Allow debugging"
Hi
Select File -> VI Properties menu option, then from the drop down like select the Window Appearance option. I suspect that for your two example VI's the setting is Custom, and in the Customize.. options the buttons you want are disabled.
You could either alter the Customize options or maybe just select Default instead.
It would generally be a good idea to read the Help covering the "windows Appearance Properties Page" and have a play with the setting on these pages you will find them very useful as time goes on hope this helps
Dannyt
EDIT Dash beaten by one minute
Edited by dannyt
Edited by xinbadaz
