Peter Laskey Posted August 26, 2010 Report Share Posted August 26, 2010 Hello, I have a database application written in LabVIEW 2010. The application gets it's data from a MySQL database server using the Database Connectivity Toolkit and MyODBC Connector. Because MyODBC is required, I have been manually running the .msi installer for this tool before installing my compiled LabVIEW application. I would like to know if it is possible to make a LabVIEW Installer Build Spec that will run the MyODBC install .msi before installing the LabVIEW components. Can anyone tell me how to do this? Thank you, Peter Laskey Quote Link to comment
jgcode Posted August 27, 2010 Report Share Posted August 27, 2010 Hi Peter You can set up the LabVIEW installer to run other installers after it. Is there a dependency on the order in this case - does the ODBC drivers have to install before your LabVIEW app installs even if they are in the same deliverable? Otherwise you could use a batch file and just script the order? Cheers -JG Quote Link to comment
Antoine Chalons Posted August 27, 2010 Report Share Posted August 27, 2010 Otherwise you could use a batch file and just script the order? I don't know about LV2010 because I haven't switched but at least in 8.6 I'm using this technique. I add the .msi to the project, include it in the installer, and have batch to launch it after installatio, works fine. Quote Link to comment
