naganathas Posted September 7, 2010 Report Posted September 7, 2010 What is equivalent to"C/C++ Pointers" in Labview programming? Quote
Tim_S Posted September 7, 2010 Report Posted September 7, 2010 What is equivalent to"C/C++ Pointers" in Labview programming? There is not an equivalent. The closest thing is data value references, which creates what operates like a pointer, however LabVIEW operates on a different concept than C/C++ does as it is data driven. The DVR didn't exist for eight full versions of LabVIEW over 20+ years, so if you're looking to use them you should reconsider how your algorithm is implemented. Tim Quote
Djed Posted September 7, 2010 Report Posted September 7, 2010 Also, LabVIEW manages memory for you, so you (typically) don't have to worry about passing everything by pointer or using pointers to allocate, etc. Quote
ShaunR Posted September 7, 2010 Report Posted September 7, 2010 (edited) It's a bit like asking "what's a LabView Wire" equivalent in C/C++ Edited September 7, 2010 by ShaunR Quote
Daklu Posted September 7, 2010 Report Posted September 7, 2010 It's a bit like asking "what's a LabView Wire" equivalent in C/C++ True, but unless the person has programmed in LV for a while and understands dataflow programming that will appear to be a perfectly valid question. Or worse, they will think the answer to your question is "variables." Quote
