Check for System control
g_sures
There is a private property for this, called Style ID. It's available with scripting. Here's a snippet.
post-10515-063400000 1284556720_thumb.pn
Thanks a lot francois. Is it possible to get the data type from that ID, or we need to have a look up table?
Regards,
Suresh Kumar.G
Hi Suresh
Some examples include:
You can get the Class by this node and infer the datatype:
post-10325-031973600 1284697114_thumb.pn
Or if you have the data you get the Datatype like this:
post-10325-073021000 1284697116_thumb.pn
Cheers
-JG
Regards,
Suresh Kumar.G
For datatype, Jon made good suggestions.
For the styles, you'll need to create a look-up table.
This "Style ID" will discriminate between System style, classic and modern... but I'm sure that the ID will change between Boolean, Combo Box & Numerics. If you want a universal look-up table, you should consider using scripting to create it: that's another question. ;)
