Daklu Posted October 14, 2010 Report Posted October 14, 2010 I'm curious what hotkey combos the rest of you use most frequently and what quick custom quick drop key combos you use. At home I have a Logitech G15 keyboard with 54 available macro keys. I keep thinking I should map LV functions to them but I just haven't gotten around to it yet. Here are the hotkeys I use most frequently: F1 - Remapped to toggle context help F2 - Rename Ctl-Shft-N - Remapped to open a new project (great for preventing cross-linking) Ctl-Shft-A - Remapped to Save As I try to set up my quick drop key combos so I can hit them all easily with only my left hand. Here are a few of them:stw - While loop (structure, while) stf - For loop stfs - Flat sequence structure stc - Case structure ste - In-place element structure stev - Event structure std - Diagram disable structure stcd - Conditional disable structure sterr - Error case structure carr - Array constant (constant, array) cb - Boolean constant 95% of my quick drop use is placing a structure of one sort or another. For some reason I haven't gotten into the habit of using it for other stuff. Quote
Darren Posted October 14, 2010 Report Posted October 14, 2010 These are the ones I use...I use shortcuts for functions and VIs as much as I use them for structures: Quick Drop Palette Object Shortcuts for Right-Handed Developers -D Quote
ShaunR Posted October 14, 2010 Report Posted October 14, 2010 std - Diagram disable structure Very disabling Quote
SuperS_5 Posted October 14, 2010 Report Posted October 14, 2010 I use these shortcuts. When I have enough desktop space, I use it over my wallpaper. Quote
Michael Aivaliotis Posted October 14, 2010 Report Posted October 14, 2010 There is also an awesome keyboard shortcuts page on our wiki here. http://labviewwiki.o...yboard_shortcut Please add any new ones discovered there. Thanks. Quote
Black Pearl Posted October 14, 2010 Report Posted October 14, 2010 I'm still working on my own plug-in key-assignments for Ctrl+N. http://lavag.org/topic/12887-discuss-quick-create-a-new-vi-from-template/ For later LV versions, you'll need to fix it on your own; Fix is in the discussions page. Felix Quote
Daklu Posted October 15, 2010 Author Report Posted October 15, 2010 There is also an awesome keyboard shortcuts page on our wiki here. Great link. I tend to forget about the wiki page. The original question is more about what everyone's favorite hotkeys are than what hotkeys are available. I thought it might give some insight into other developers' workflow. (i.e. Mapping context help to F1 and New Project to Ctl-Shft-N is a pretty good clue I use them a lot while coding.) Quote
