"Item moved within library."
mje
Any ideas on how to coax more information out of LabVIEW on this one?
post-11742-0-43778300-1289580238_thumb.p
When I open my library, immediately the dirty little "*" appears in the project explorer. Trying to close the project prompts me to save my "changes", shown above. If I save the file, the time stamp on the file indeed does change, but the contents do not. This means the project is forever dirty.
Running a checksum recursively on the library folder shows no changes in any of the file contents. However, when the file is included in a project, the problem does not happen.
Ideas?
A) Is this in LV 2010?
B) Does it involve a library that contains another library? (The inner library can be any type of library -- lvlib, lvclass, xctl, lvsc.)
If the answer to both of those questions is "yes," then it's known and should be fixed in LV 2010 SP1. If not, please post a reproducing example on ni.com so it can be evaluated and hopefully fixed.
