gagawy Posted November 28, 2010 Report Share Posted November 28, 2010 hi is it possible to make interfacing by using labview directly with ISA or PCI bus without using the national instruments devices ? please if there is some thing like this please guide me . regards Quote Link to comment
SuperS_5 Posted November 28, 2010 Report Share Posted November 28, 2010 Hi, I have always seen hardware communications implemented via dll calls from LabVIEW. In my very limited experience in the area, drivers where provided. I then could use the "Call Library Function Node" to access the dll files required. (I have only used this from Windows) Quote Link to comment
gagawy Posted November 29, 2010 Author Report Share Posted November 29, 2010 Hi, I have always seen hardware communications implemented via dll calls from LabVIEW. In my very limited experience in the area, drivers where provided. I then could use the "Call Library Function Node" to access the dll files required. (I have only used this from Windows) Hi i have understand your answer because you didnit answer me is there direct interfacing or not ? is there web site link can help me in what you say about if it is connected to my question? thank you Quote Link to comment
Grampa_of_Oliva_n_Eden Posted November 29, 2010 Report Share Posted November 29, 2010 Hi i have understand your answer because you didnit answer me is there direct interfacing or not ? is there web site link can help me in what you say about if it is connected to my question? thank you Got to the NI web-site and search for "VISA Driver development Wizard". It will let you poke and peek at the registers. Not sure if it supports ISA but PCI yes. No NI hardware required. Ben Quote Link to comment
gagawy Posted November 29, 2010 Author Report Share Posted November 29, 2010 sorry could you please explain more Quote Link to comment
Grampa_of_Oliva_n_Eden Posted November 29, 2010 Report Share Posted November 29, 2010 sorry could you please explain more ??? Enter "ni.com" in your browser and go to the NI web-site. at the top of the page enter the text I posted into the search box. Hit search. One of those links should point at a tutorial that will tell you all about the VISA driver development Wizard (which will let you develop code to peek and poke the registers on the PCI buss). Ben Quote Link to comment
gagawy Posted November 29, 2010 Author Report Share Posted November 29, 2010 thank you my friend i'm very very happy for this great information i wish if we keep in contact in case if you interest about the same subject (direct interfacing without externat or additional equipment ) regards Quote Link to comment
Grampa_of_Oliva_n_Eden Posted November 29, 2010 Report Share Posted November 29, 2010 thank you my friend i'm very very happy for this great information i wish if we keep in contact in case if you interest about the same subject (direct interfacing without externat or additional equipment ) regards I only check in here occationally when not on the road. If you are succesful with that information it would be helpful to others (like yourself) sometime in the future if you posted what you learned (good or bad). Take care, Ben Quote Link to comment
gagawy Posted November 29, 2010 Author Report Share Posted November 29, 2010 Dear Ben By your help i start immediately to read and serch in the web sites and i got this video on you tube explain some thing about our subject (http://www.youtube.com/watch?v=W4VZHwpSW1M) and i will try to look for details or projects about it because if we succeed in this subject this will decreas the cost of purchase the DAQ and other additional equipments and saving money thank you very much Quote Link to comment
