Replaying Captured Front Panel Events
T Clancy
Just wondering if anyone knows anything about capturing events so that they can be replayed in the correct sequence and time order. So
that it will replay the application in the exact same way the previous user used the application (No text input, just clicks representing touch screen user input).
Thanks
Tim
One example way to approach it could be:
If you have a UI and a Controller
And the UI sends messages to the Controller for each button press
And for each button press, the action was also logged to disk
Then you could read the file back and and send the messages directly to the Controller
Queues are good for this sort of thing. they give you inherent FIFO sequencing. You can use the "Event" structure to place the controls' refnum on the queue then replicate the changes by emptying the queue.
Edited by ShaunR
You could register dynamic events for the controls you want to watch or record. That way you just have to write a "recorder" VI, no need to change anything in the VIs you want to watch. Put the events received in a queue or save them to a file and you have anything you need to replay the events.
post-17093-0-50914700-1291279928_thumb.p
There is a well-established design pattern to do exactly what you want. See the Memento Pattern in GoF Design Patterns. Also look at how you can combine this with the Command Pattern. You can support undo operations; the different commands and their parameters can be of arbitrary complexity, and can each have its own parameters. I highly recommend you take a look at this proven approach.
