Ton Plomp Posted December 5, 2010 Report Posted December 5, 2010 Name: Align and distribute Submitter: Ton Plomp Submitted: 05 Dec 2010 File Updated: 23 Jan 2011 Category: General LabVIEW Version: 2009 License Type: BSD (Most common) Align Distribute objects v1.2.0 Copyright © 2010, Ton Plomp All rights reserved. Author: Ton Plomp LAVA Name: Ton Plomp Contact Info: Contact via PM on lavag.org LabVIEW Versions: LabVIEW 2009 and up Dependencies: No dependencies, demo VI needs the OpenG time library Description: A set of VIs to align or distribute a set of points or objects, they behave similar to the align and distribute functions in the LabVIEW IDE. These tools are usefull when dealing with objects that needs to be rearranged. The set of VIs is bundled in one polymorphic VI (align_distribute.vi) that has the following tree layout -Align -Top -point -rectangle -Left -point -rectangle -Bottom -point -rectangle -Right -point -rectangle -Vertical center -point -rectangle -Horizontal center -point -rectangle -Vertical center -point -rectangle -Distribute -Top -Left -Bottom -Right -Vertical Centers -Vertical Gaps -Vertical Compress -Horizontal Centers -Horizontal Gaps -Horizontal Compress Installation and instructions: Use the VI whereever you want, or install it into your user.lib with VI Package manage (http://www.jki-soft.com/vipm) Examples: The zip-file includes one DemoVI that moves front panel controls around Known Issues: Acknowledgements: Icons are supplied by National Instruments in the LabVIEW IDE Version History: AlignDistribute - 1.2.0 (Released 2010-06-28) ============================================= - 0000021: [bug] The palette shows Align Distribute.vi as name. v1.1.0: Initial public release of the code. License: This code licensed under the BSD license ==============Start of license================== Copyright © 2010, Ton Plomp All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met: 1. Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer. 2. Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution. 3. All advertising materials mentioning features or use of this software must display the following acknowledgement: This product includes software developed by the . 4. Neither the name of the nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission. THIS SOFTWARE IS PROVIDED BY ''AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. ==============End of license================== Support: If you have any problems with this code or want to suggest features: please go to lavag.org and Navigate to LAVA > Resources > Code Repository (Certified) and search for the "Distribute objects" support page. Distribution: This code was downloaded from the LAVA Code Repository found at lavag.org Click here to download this file Quote
Bobillier Posted December 12, 2014 Report Posted December 12, 2014 Hi TonToday i have installed this library on a new PC and i notice this package is not correct. All vi's have broken arrow on them because library file seems to be bad. If you disconnect each vi from this library, the vi's become ok.I looked on my old PC under XP and see same thing.Best regardsEric Bobillier Quote
