Jubilee Posted January 14, 2011 Report Posted January 14, 2011 Is there a native LV tool for updating the costumers' version of the software? Till now the costumers simply had to download a new version and install it above the old one. This is the first time I'm trying to build/apply an auto update LV tool and I wonder if one of the next tools can work with LV: http://www.chromium....dates-courgette http://code.google.com/p/sparkleplus/ I can add an md5 diff check on the users application startup yet I want to send the user as little data as possible and not the whole exe for each small change. Thanks, Dror. Quote
Tim_S Posted January 14, 2011 Report Posted January 14, 2011 Is there a native LV tool for updating the costumers' version of the software? Till now the costumers simply had to download a new version and install it above the old one. I assume you're talking about updating the LabVIEW development or run-time environment. The answer is no to that. If you are talking about an application written in LabVIEW, then you may want to look at VIPM. Tim Quote
crossrulz Posted January 14, 2011 Report Posted January 14, 2011 I assume you're talking about updating the LabVIEW development or run-time environment. The answer is no to that. Actually, there's an NI Update Service. I can't use it because of our network, but it's there. Quote
Jubilee Posted January 19, 2011 Author Report Posted January 19, 2011 Thanks. I'll look into it. As for whether or not courgette can work with LV I guess I'll have to ask them. Quote
