Graph discrete Y axis
Sharon_
Hi ,
Is it possible to have discrete values on Y axis?
I mean the values like---- 1 2 63 64. .
I would like to have something like this.I am not interested in other values.blink.gif
65 |
64 |
2 |
1 |
________________________(x --->)
I browsed thru' all the examples given and tried some property values. Nothing worked. oops.gif
Hello,
It's possible, do things in that order :
1. set the graph property "Y Scale.Uniform Marker Spacing?" to false
2. set the graph property "Y Scale.Range.Maximum" to 65
3. set the graph property "Y Scale.Range.Minimum" to 1
4. set the graph property "Y Scale.Marker Values[]" to an array of DBL [1;2;64;65]
Hope this helps
Hello,
Hope this helps
Hi Antoine,
I tried but the scale is still 1 to 65, though the value are invisible. I would like to see if it possible to get the y axis values(1,2,64 and 65) with a uniform spacing. unsure.gif
Thanks for your time..!!!
Sharon.
