MartinMcD Posted March 4, 2011 Report Posted March 4, 2011 Hello all, I am using the 'Get Image' method of a graph control to get the image data. I'd then like to use the Clipboard.Write method to copy the image to the clipboard. Does anyone know how to do this please? I know the control has the 'Export Image' method but the results are not great with this function. Thank you, Martin Quote
Antoine Chalons Posted March 4, 2011 Report Posted March 4, 2011 Hello all, I am using the 'Get Image' method of a graph control to get the image data. I'd then like to use the Clipboard.Write method to copy the image to the clipboard. Does anyone know how to do this please? I know the control has the 'Export Image' method but the results are not great with this function. Thank you, Martin There is a way I think, you should have a look at the CCT, it has a function to put data into windows' clipboard. Quote
MartinMcD Posted March 4, 2011 Author Report Posted March 4, 2011 Brilliant, thank you, this works perfectly. A good way to end the week Thanks again, Martin Quote
Ton Plomp Posted March 4, 2011 Report Posted March 4, 2011 Brilliant, thank you, this works perfectly. A good way to end the week The copy to clipboard code was provided by Rolf Kalbermatter. Ton Quote
