dcg Posted March 21, 2011 Report Posted March 21, 2011 Hello How to I conctruct an ROI for a concentric rake tool from two circles already found in the image. I want to use the measurements of the ineer cirlce and the outer circle to form the boundries for the rake but am unable to do so. HELP Bye Quote
Antoine Chalons Posted March 21, 2011 Report Posted March 21, 2011 Hi, Since you didn't answer back on this thread I thought you found out how to do it. Are you still at the same point or do you go any further? You're not far from the solution, with you inner and outer circles you can define an annulus and then use the Annulus to ROI vi to then use the rake. Do you need an example? Quote
Antoine Chalons Posted March 21, 2011 Report Posted March 21, 2011 Here is a simple modicifation of the VI you posted on the first thread. I used another VI for the rake, I think it's easier to use. Hope this helps 10 ATTEMPT AT IMAQ.vi Quote
dcg Posted March 23, 2011 Author Report Posted March 23, 2011 Hello Antoine Sorry I did not get back to you sooner. I was working away frantically at it but I was also dealing with other issues with my project. I was working on a different VI called rotation detect when I reposted that last message. The modifications that you have made are first class thank you so much for your help. THANK YOU THANK YOU THANK YOU BYE Quote
