James McAnanama Posted September 3, 2004 Report Posted September 3, 2004 Is there an easy way to detect another computer on a network using Labview? (as opposed to System Exec & Ping). I want my Labview app to periodically check the health of key computers on my network. Quote
Norm Kirchner Posted September 3, 2004 Report Posted September 3, 2004 If they have any ports open, then you can attempt to open a TCP connection to that computer and that port. If it doesn't timeout/crapout then the PC is running. As far as it's status, that's another issue all together Quote
aledain Posted September 6, 2004 Report Posted September 6, 2004 There is a ping VI in the NI knowledge base somewhere. I also have one contributed by a generous sole. However, can a small app be written for each of the key machines that sends a message every N seconds. If your monitor PC does not receive that message every N + a little bit, seconds, then the PC is dead or off the network. Sort of like a watchdog. You could use TCPIP or datasocket for a quicker implementation. As for the message, I'd get it to send it's IP address. Quote
James McAnanama Posted September 7, 2004 Author Report Posted September 7, 2004 I like the watchdog approach. However, some of the devices I am looking at are SBCs that are streaming data to another application, and they don't support multiple connections. Thanks for reference to the NI Knowledge base. I guess I am stuck with sytem exec. This is fine - I am just surprised that LV doesn't have built in support for Ping. Cheers, James Quote
