GoUp Posted April 9, 2011 Report Posted April 9, 2011 Hello. I tried to import a vrml file to LabView and everything is working, except the background. I now found that according to http://digital.ni.co...62575CA005747E0 the background feature is unsupported. Is there a way to change the background in a 3D scene? I found some background color properties, but I found the help a little confusing (I am a novice). Any help is much appreciated. Kind regards, Greg Quote
COsiecki Posted April 11, 2011 Report Posted April 11, 2011 The only way I have ever had a background in a 3D scene was to create a large cube or sphere around my scene and then apply the background texture to that. You need to make it quite large, on the order of 100 to 1000 on a side for a cube. I took the 3D demo with the Sun, Earth, and Moon and added a starry background for fun before. I don't know if that is what you meant, but I hope it helps. Hello. I tried to import a vrml file to LabView and everything is working, except the background. I now found that according to http://digital.ni.co...62575CA005747E0 the background feature is unsupported. Is there a way to change the background in a 3D scene? I found some background color properties, but I found the help a little confusing (I am a novice). Any help is much appreciated. Kind regards, Greg Quote
ShaunR Posted April 11, 2011 Report Posted April 11, 2011 The background colour property node accepts RGB and Alpha values between 0 and 1 (i.e 1/255). Quote
GoUp Posted April 11, 2011 Author Report Posted April 11, 2011 @COsiecki Yes I tried to make a huge 3d cube, but then when you rotate the scene you see that there is a huge cube. Also I think that rendering a huge cube is also time consuming. @ShaunR Thank you for your response. This is exactly what I was looking for. Now even the build-in help makes a little more sense to me. Kind regards, Greg Quote
