Jordan Kuehn Posted July 21, 2011 Report Posted July 21, 2011 Here's possibly a simple question. I'd like to have a main program that launches subvis which provide the main UI. I don't want the subVIs to handle events though, I want the single controlling process to get the events and handle them. Is there an easy way to do this, or will I have to create custom user events for every single one I want using control references? Quote
Tim_S Posted July 21, 2011 Report Posted July 21, 2011 Here's possibly a simple question. I'd like to have a main program that launches subvis which provide the main UI. I don't want the subVIs to handle events though, I want the single controlling process to get the events and handle them. Is there an easy way to do this, or will I have to create custom user events for every single one I want using control references? Offhand that sounds like a Producer-Consumer model. You should be able to find an example on NI's website. Tim Quote
Wire Warrior Posted July 21, 2011 Report Posted July 21, 2011 jkuehn, You can do what your wanting by using dynamic events. If you search for that in the example finder I believe you will find some examples. Basically you need to pass the reference for the control of the subVI to the 'control' VI where you will register the specific type of event you want to process, mouse over, value change, etc. Jason Quote
Jordan Kuehn Posted July 21, 2011 Author Report Posted July 21, 2011 the problem is that the UI code exists within the SubVIs. I will be pumping data into them in a producer-consumer fashion, but need to get User Interface events from them. jkuehn, You can do what your wanting by using dynamic events. If you search for that in the example finder I believe you will find some examples. Basically you need to pass the reference for the control of the subVI to the 'control' VI where you will register the specific type of event you want to process, mouse over, value change, etc. Jason Ok. That's what I was hoping to avoid, but I can make that work. Quote
PaulL Posted July 22, 2011 Report Posted July 22, 2011 Well, an approach we use differs in letter from what you are attempting, but maybe accomplishes the larger goal. Our Views do handle control events (that's the easiest place to handle them!), but when an event happens they send a message to the Controller, which instructs the Model what to do. In some applications the messages are commands using the Command Pattern, so that we can use one message type (of the top-level Command class) and therefore a single message pipe (user event, shared variable, queue, or other messaging system). (In practice we often send basic shared variables from the View and then translate these to Commands before sending them to the Controller, because the messages may come from various sources, but that is a fine point.) Paul Quote
Jordan Kuehn Posted July 23, 2011 Author Report Posted July 23, 2011 Well, an approach we use differs in letter from what you are attempting, but maybe accomplishes the larger goal. Our Views do handle control events (that's the easiest place to handle them!), but when an event happens they send a message to the Controller, which instructs the Model what to do. In some applications the messages are commands using the Command Pattern, so that we can use one message type (of the top-level Command class) and therefore a single message pipe (user event, shared variable, queue, or other messaging system). (In practice we often send basic shared variables from the View and then translate these to Commands before sending them to the Controller, because the messages may come from various sources, but that is a fine point.) Paul I've read your whitepaper and I like your approach in general. Have you released this code for public use or is it proprietary? You can pm me if it's going to derail this forum thread. Quote
PaulL Posted July 23, 2011 Report Posted July 23, 2011 I've read your whitepaper and I like your approach in general. Have you released this code for public use or is it proprietary? You can pm me if it's going to derail this forum thread. We've learned a lot since I wrote the white paper, and I have since created a system component template that I consider to be immensely successful. It allows us to concentrate on the specific application rather than the details of messaging and the like since those are a given, and creating and debugging an application is orders of magnitude more straightforward, we have found. We have pondered releasing the template in some manner, but we haven't yet. Will you be at NI Week? If so, perhaps the best thing is to attend my session, Track: Software DevelopmentTechniques Session ID: TS1665 Title: System ComponentsWith Object-Oriented Design Patterns Speaker(s): Paul Lotz with LowellObservatory Date: Tuesday, August 2 Time: 1:00 PM Room: 14 (located on the 4thfloor of the Austin Convention Center), and we can talk then about what would be most helpful.... 1 Quote
Jordan Kuehn Posted July 24, 2011 Author Report Posted July 24, 2011 I'll put it on my calendar. See you then. Quote
