VI missing icon when loaded into subpanel of built application
I have a top level VI that has a subpanel. I open a VI containing a class control using VI Server, set the class control value, invoke run then load it into the subpanel. Everything works fine.
However when I build the top level VI the class control icon in the loaded subpanel is missing. Everything is otherwise functional.
The class I am using is from the LapDog Messaging Library which gets installed in vi.lib. I included the VI package in the attached project file.
post-17905-0-41685400-1313248100_thumb.p
post-17905-0-41518500-1313248119_thumb.p
Empty Icon - LV2010.zip
This may have been less alarming but I don't know.
I would be inclined to say no based on the fact this already has a meaning.
Therefore if you saw it in RTE is it actually the ultimate ancestor or is it a class with its icon stripped?
Least I know what the ? means now....
