Sarah83 Posted September 28, 2004 Report Posted September 28, 2004 Hi! If I like to scroll an object on the front panel e.g a button, and I will scroll it for only a millimeter, every time the object is scrolling with the "fence grid" from the blank front panel. Can I switch-off this function somehow? Quote
didierj Posted September 28, 2004 Report Posted September 28, 2004 Do you mean this from the Tools->Options: Disable "Enable panel grid alignment" and you have a front panel like "LV prior 7.0" Didier Quote
Sarah83 Posted September 28, 2004 Author Report Posted September 28, 2004 Do you mean this from the Tools->Options: Disable "Enable panel grid alignment" and you have a front panel like "LV prior 7.0" Didier 2031[/snapback] Yes, thanks :worship: Oh, the diagram have a grit, too :thumbup: Someone said you can enable the grid alignment with a shortcut, is this right? Quote
jpdrolet Posted September 28, 2004 Report Posted September 28, 2004 Yes, thanks :worship: Oh, the diagram have a grit, too :thumbup: Someone said you can enable the grid alignment with a shortcut, is this right? 2033[/snapback] While moving an object with grid on, hit "g" to toggle the grid. On a related note, use "a" to toggle wire autorouting on the diagram. Quote
Sarah83 Posted September 28, 2004 Author Report Posted September 28, 2004 While moving an object with grid on, hit "g" to toggle the grid.On a related note, use "a" to toggle wire autorouting on the diagram. 2035[/snapback] Thanks, this is for what I have searched. Quote
Mike Ashe Posted December 31, 2004 Report Posted December 31, 2004 Has anyone else noticed that if you have several items spaced out just the way you want them, then you select them all and hit shift-up|down|left|right that as they move they INDIVIDUALLY snap to the gird, ruining your spacing? Most annoying. Quote
ahlers01 Posted December 31, 2004 Report Posted December 31, 2004 Has anyone else noticed that if you have several items spaced out just the way you want them, then you select them all and hit shift-up|down|left|right that as they move they INDIVIDUALLY snap to the gird, ruining your spacing? Most annoying. 3267[/snapback] Haven't noticed that yet, but you can use the 'Group' feature from the 'Reorder' icon menu to group those items into one grouped item so they keep their spacing Quote
Mike Ashe Posted December 31, 2004 Report Posted December 31, 2004 Yes, you can group, but that is a hassle if you are doing a lot of controls and moving stuff hither and yon while trying to lay out a new interface. Hmm, maybe I should submit a bug report. Quote
Michael Aivaliotis Posted December 31, 2004 Report Posted December 31, 2004 Has anyone else noticed that if you have several items spaced out just the way you want them, then you select them all and hit shift-up|down|left|right that as they move they INDIVIDUALLY snap to the gird, ruining your spacing? Most annoying. 3267[/snapback] I honestly have never used the Grid feature... . It's one of those things I always turn off. It's easier to align things relative to other controls rather than the grid. The grid is never in the right place that I want it to be. Most of the time, what looks natural to the eye does not conform to the grid. I realize this was a "most requested feature" from NI customers... I think I requested it as well . But in practice, no good. Quote
Mike Ashe Posted January 1, 2005 Report Posted January 1, 2005 ...I realize this was a "most requested feature" from NI customers... I think I requested it as well . But in practice, no good. 3290[/snapback] I think the grid is useful and has its place, but is also in need of a little more refinement before it is fully ready for prime time. Don't get me wrong, I am very glad NI implemented it and don't want to seem ungrateful. I just wish it had a few things "polished up" a bit. Perhaps in LV 8? Quote
