case structure
I want to use case structure vi, that has a prolem. it has a Initial value(it is a string),but case run over,it will return a return value. I will use the return value to control this case structrue as a condition station .meanwhile ,the return value may use as a input value.
what can I do to solve this problem?
i mean I want to set two types of control condition,the first one is the initial value and the initial value is a string。 the other one is the value when the forward case structure run over the case structure return。meanwhile ,this value is Dynamic data。
I am sorry... I still don't grasp what you're asking for. I am guessing that English is not your native language and you're using translation tools to post. Something is being lost in mechanical translation. Could you try posting your question in your native language... there may be someone on the forums that can provide a better translation.
