hellow everybody
does anyone know how to build vi that calculates the rate of data transfer and indicates it on a monitor.
i want to build an application to exchange files and i want to display the rate of data transfer.
thank you
Data transfer would be bytes per second. Bytes would be number of U8s or length of string. Seconds would be the dt between reads. It's pretty trivial from there.
What protocol are you using to transfer files? I would also be interested in this but more to see how much data is being transferred back and forth to view a remote panel. That's not something you can easily access AFAIK.
Commonly this would require you breaking your transfer down into chunks. You can then easily time each chunk as you would benchmark any VI (check the example finder) and knowing the size get to the bytes/second
This chunking is going to happen in the tpc stack anyway so don't think it would add much overhead. Not aware of a way to time it whilst in the TCP write function.
Cheers,
James
(null)
