LabWindows question
MikaelH
Hi Guys
Sorry for using such a bad word as LabWindows here on LAVA, but I have a development team in Fremont and Shanghai that develop all their code in LabWindows. Since you can't do all cool stuff there I had to write the intelligent code in LabVIEW, and have them to call my LV exe file.
I let them control the behaviour to my exe file with arguments so they can call it like this: MES_Finish.exe --PreCure or MES_Finish.exe –PostCure
But the developers say that LabWindows can't call exe files with arguments.
Does anybody know if this is true?
A work around that didn't work either, was for them to call 2 batch files with the argument syntax in.
Cheers,
Mike
Here is a quote from the CVi documentation:
LaunchExecutable
int LaunchExecutable (char filename[]);
Purpose
Starts running a program and returns without waiting for the program to exit.
Note If you want to wait for the program to exit, use the system function in the ANSI C Library.
The program must be an actual executable; that is, you cannot launch commands intrinsic to a command interpreter.
The executable can be either a DOS or Windows executable, including *.exe, *.com, *.bat, and *.pif files.
.exe, .com, and .bat DOS programs use the settings in _default.pif (in the Windows directory) when running. You can change their priority, display options, and so on., by editing _default.pif or by creating another .pif file. Refer to www.msdn.com for information about creating and editing .pif files.
If you need to execute a command built into command.com such as copy, dir, and others, you can call LaunchExecutable with the following command:
command.com /C DosCommand args
where DosCommand is the shell command you want to execute. For example, the following command string copies file.tmp from the temp directory to the tmp directory:
command.com /C copy c:\\temp\\file.tmp c:\\tmp
Note If you want to monitor whether the launched executable has terminated, use LaunchExecutableEx.
In other words: It should work...
It definitely works. I played around with the different LW API functions. You can even use the system() function that is part of the ANSI C library. My example command was:
char *cmd="cmd /k echo \"Hello world\"";
Here are the options:
// Does not wait for the executable to finish.
LaunchExecutable(cmd);
// Waits for the executable to finish. Even part of the ANSI C standard.
system(cmd);
// Runs the executable...
int procHandle = 0;
LaunchExecutableEx(cmd, LE_SHOWNORMAL, &procHandle);
// .. and enters a loop (timing 0.1s) that waits for the executable to finish.
while(!ExecutableHasTerminated(procHandle))
Delay(0.1);
There's really no problem here, perhaps there was one years ago in the stone age of programming, I have no clue :-)
And why not, I can create a DLL also...or convince them to migrate to a real programing language ;-)
That may be an even better idea ;-)
