Front panel control enable
I have two controls in my front panel. one is numeric and another one is string.
I want the user first enter the numeric control and then go for string control.
so what i'm looking is that once the user entered the numeric value, then the "string input" should enable and at the same time the mouse cursor should blink in it.
if the numeric data is not yet entered any value then the string input must not visible or enabled ...
possible ??
Thanks.
Yes, have a look at the Disabled property of your string control. You can use the Value property of the numeric control to decide the disable state of your string control. The KeyFocus property will move the cursor to the string control.
