Raviramesh Posted August 3, 2012 Report Posted August 3, 2012 Dear all, I want to latch the two condition separately whenever it satisfies and some where am missing something to latch ..kindly help me to get rid out of this . lemme explain If condition one falls on the range 3 to 10 then it should be latched as True no matter what then. if condition two falls on the range 0 to 2 then it should be latched as False and has to reset the condition 1 and vice versa . Herewith i have attached the VI for your kind persual. am waiting for your valuable reply. Thanks in advance. latching.vi Quote
jcarmody Posted August 3, 2012 Report Posted August 3, 2012 I'm not sure what you mean. You wrote "condition one" and "condition two", but your vi only has one input and three outputs. Quote
asbo Posted August 5, 2012 Report Posted August 5, 2012 C:NI%20Certifications%20Exams%20Preparationcld_sample_exams_englishSimple%20Latch%20-%20Unlatch.png You need to upload images before you can link to them. Quote
KWaris Posted August 5, 2012 Report Posted August 5, 2012 I could not get the snippet here. Tried to drag the .png file in my reply. It dint work. Any ideas? @Raviramesh, Try the above Simple Latch - unlatch.vi will work for you. i will try again to load the snippet Quote
Raviramesh Posted August 6, 2012 Author Report Posted August 6, 2012 @jcarmody n @AustinCann thanks for your reply... @jcarmody Single input has to check two condition as indicated in my first post...just for understanding purpose, i had shown three output..actually X + Y indicated in the program is the correct output rest of them not required... @AustinCan As am not updated to version 11, i couldnt open your vi in the version 10. could you please upload it in v10. thank you single input --->it has to check two condition here and latch accordingly---> single case structure --->single output please ask me anymore input u need to understand further. Thanks in advance Quote
jcarmody Posted August 6, 2012 Report Posted August 6, 2012 If condition one falls on the range 3 to 10 then it should be latched as True no matter what then. if condition two falls on the range 0 to 2 then it should be latched as False and has to reset the condition 1 and vice versa . What shoud the output be when the input is less than 0, between 2 and 3 or greater than 10? Quote
Raviramesh Posted August 6, 2012 Author Report Posted August 6, 2012 @jcarmody assume there wont be negative value as well as greater than 10 ...if i connect any sensor that will start from 0 to 10...if something found..value will be varying 3 to 10 but problem is sometimes it comes to zero at any instant due to error this should not be happened...thats y i want to latch it as true...if nothing found 0 will be the value from sensor but due to tolerance limit sometimes it will also be varying from 0 to 2 at any instant , this value i want to latch as false and this will be continued...hope u understand the problem...and help me out of this... Thank you very much for your reply again... Quote
jcarmody Posted August 6, 2012 Report Posted August 6, 2012 I don't understand what you mean by 'latch'. It sounds like you want to ignore the occasional error when the input comes to zero (0-2) and keep the output True, but for how long? Perhaps you mean that whatever condition exists at the beginning of execution should persist throughout. Do you want the output to be True if it begins between 3 and 10 and never go False, regardless of changes in the input? Quote
Raviramesh Posted August 8, 2012 Author Report Posted August 8, 2012 @jcarmody yes exactly, i want to ignore the occasional error..output will be true until (0-2) conditions falls on the range and change it to false similarly output will be false(latch) until (3-10) falls on the range and change it to true(latch)...hope u understand... Do you want the output to be True if it begins between 3 and 10 and never go False, regardless of changes in the input? yes exactly thats where i want to latch it as true until it falls on the range 0-2. but problem is some time it touches 1 or 2 and latch has been released and it goes to false due to this overshooting occurs in the output..it should be true until it touches 0... hope u understand.. Thanks for your reply Quote
jcarmody Posted August 8, 2012 Report Posted August 8, 2012 Perhaps this? It will be True after the input goes above 3 and will go False if the input = 0. It won't change if the input is 1 or 2. Untitled 1.vi 1 Quote
Raviramesh Posted August 10, 2012 Author Report Posted August 10, 2012 (edited) @jcarmody... i always thought of true or false for case structure ..it dint strke me at all this simple method instead i tried something complex...thanks for your solution... its really good ...i cud avoid that occassional error but that 0 rare error bit difficult to avoid ...will try to increase the loop speed to avoid that instant 0 error which happens in rare occassion. anyhow dude....thanks for your reply and solution...really nice talking to you... Edited August 10, 2012 by Raviramesh Quote
jcarmody Posted August 10, 2012 Report Posted August 10, 2012 You're welcome; I hope you stick around and enjoy/enrich LAVA. Quote
