Ano Ano Posted October 5, 2012 Report Posted October 5, 2012 Hello, I am building an application that interrogates up to 4 NI-9191 wirelessly. I want the application to identify and use/connect only the NI-9191 that I will supply to the client. The reason for this is to void cheeky clients that might be tempted to "replicate" the system. Is there any way that I can write a specific number/id to the NI-9191 so that when the application is launched, to read all wireless NI-9191 out there and connect only to the devices with this specific number? Quote
Ryan Podsim Posted October 5, 2012 Report Posted October 5, 2012 (edited) I would imagine, you could use the serial number or MAC address. Note to consider: What would happen when the NI 9191 fails and your client needs to replace one? Also, if your that worried about you client attempting to replicate the system, why are you doing business with them or charge appropriately? Edited October 5, 2012 by Ryan Podsim Quote
Ano Ano Posted October 8, 2012 Author Report Posted October 8, 2012 Thank you for your prompt reply. The management wants to ensure that no one will/can replicate the system regardless where we sell it. So its not a particular dodgy client. In essence what I as the developer want to do is find a security method so that the software works with specific devices (or choose from a list, incase one fails) and there is some sort of license key. This license key needs to be in the same methodology as with the windows keys ie I burn "X" amount of cd/dvd with the same software and have a set of keys that will activate the program. Quote
jcarmody Posted October 8, 2012 Report Posted October 8, 2012 Have you considered NI's Third-Party Licensing and Activation Toolkit? Quote
JamesMc86 Posted October 15, 2012 Report Posted October 15, 2012 Something I have done for rt targets is combine the serial number and mac address into a string and encrypt with a specific key to produce a licence key which could be checked on boot. You could probably do a similar thing with the serial numbers of the 9191s. Quote
