Triggering Boolean Events in the cluster within a 2d array
I had never known that the controls inside the cluster contained in the 2d array were unavailable to be used in the Edit Event Handling for this case dialog box.
So I just did my best to trigger the events for the boolean controls. Please see attached my attempt.
I will be glad to know there is a better way to achieve this. Any ideas?
Kind Regards
Austin
Triggering Events For Booleans in an Array.zip
In your code the event is triggered when any of the fields inside the cluster is modified.
Have a look at the first image I posted to see how you can get a specific field inside the cluster.
First we caste the ArrElem to a cluster, then we get all elements inside the cluster, and afterthat we take the third element (the boolean) and register the event for that control only.
Here's your code:
(spot the differences)
Ton
