Grey Posted November 28, 2012 Report Share Posted November 28, 2012 Hi, I'm involving in a excel database project where i need a help. I want to find the duplicates entries in 1D array and need to know indexes of them. . actually i have the 2D array with me,, i'm slicing column A of the 2D array and finding the duplicate entry's indexes. Based on the duplicates indexes i want to modify the 2D array accordingly. I googled and find some info but not able to solve still. thanks. Quote Link to comment
hooovahh Posted November 28, 2012 Report Share Posted November 28, 2012 Well this isn't a VBA or Excel forum, so you will likely find better answers elsewhere. If this is being done in LabVIEW it is quite easy. You use the OpenG Array package and use the "Remove Duplicates" function, which returns the indicies that were removed. Then you can use the Delete From Array providing a 2D array and then removing columns or rows, at the indicies found earlier. 1 Quote Link to comment
Grey Posted November 29, 2012 Author Report Share Posted November 29, 2012 Perfect. OpenG helped me a lot. in fact i came to know what is VIPM, Open G pallets and how to install. great stuff to know. thanks hooovahh! Quote Link to comment
