Paulo Almeida Posted November 24, 2004 Report Posted November 24, 2004 Hi, I have several variables wich I visualize in a waveform chart. Associating a checkbox for each variable I want visualize the selected varables in same chart using the mode overplay plots. This means I must have multiple combinations of plots and there are no few. if have six variables, it is ........ There are otherway to visualize the selected variables in same chart whitout using several charts??? Quote
malef Posted November 24, 2004 Report Posted November 24, 2004 Put all your data in one plot and make those invisible which are not relevant at the moment. Use transparent colour for this purpose. See :camera: Quote
Paulo Almeida Posted November 24, 2004 Author Report Posted November 24, 2004 malef said: Put all your data in one plot and make those invisible which are not relevant at the moment.Use transparent colour for this purpose. See :camera: 2752[/snapback] You are a genius :worship: , it's work Thank you very much, i spend all nigth think in that. Where i can see the codes of colores?? Quote
PJM_labview Posted November 24, 2004 Report Posted November 24, 2004 Paulo Almeida said: Where i can see the codes of colores?? Right click on the u32 (in the color array) and replace it by a color constant PJM Quote
malef Posted November 25, 2004 Report Posted November 25, 2004 There is a nice Color Palette on http://www.sullutions.com/LabVIEW.html or have a look at "RGB to Color.vi" from the Picture Functions palette. A "Framed Color Box Constant" makes more sense and is better understandable than numerics. P.S. Thanks for praise - I just realized a suggestion from another forum. Quote
