hooovahh Posted January 18, 2013 Report Posted January 18, 2013 Okay I swear I saw this somewhere but I can't seem to get it to work. If I have a subpanel and I load a VI into it, then run the VI and resize the subpanel (causing the VI in it to resize) why does my "Panel Resize" event not fire in that VI? Attached is a quick test. Run Child and see the "NewBnds" value change as you resize. Now run Parent and resize. Notice that "NewBnds" does not change. Crosspost SubPanel Resize Test.zip Quote
Popular Post Darin Posted January 18, 2013 Popular Post Report Posted January 18, 2013 I usually stick with the Pane Size events, I believe that those will fire as expected in the subPanel. 5 Quote
hooovahh Posted January 18, 2013 Author Report Posted January 18, 2013 (edited) I usually stick with the Pane Size events, I believe that those will fire as expected in the subPanel. Okay so the Pane Size event does fire, but as shown in my example, the Panel Resize does not. Edit: Thanks for the cross post. Edited January 18, 2013 by hooovahh Quote
JackDunaway Posted January 19, 2013 Report Posted January 19, 2013 I usually stick with the Pane Size events, I believe that those will fire as expected in the subPanel. Great tip! Hearty +1! In the past, I've brokered resize events from the parent into the children using the application's interprocess messaging -- using Pane resize events will simplify this :-) Quote
Stobber Posted February 12, 2013 Report Posted February 12, 2013 I noticed about a year ago that there are several properties, methods, and events that only work with single-pane VIs. Pretty much everything called "Panel" changes (or breaks) its behavior when you add a splitter or subpanel to the FP. In those situations, as others have recommended, use the "Pane" events when possible, and beware coordinate system conversions between "Panel" and "Pane" properties. Quote
