i want to use subpanel as our UI. I can add new vi to our project if neccessary, but i do not need to change my application. just copy the new vi to the plugin folder.
the attachment is my test program.
i have heard that the application use subpanel can not display the new plugin vi if not complie the source program. but right now . i can use the Subpanel.exe to display the new vi which is copied by copy File.vi
Maybe i did not consider comprehensively. please point out my program's bug.
Thank you!
test86.zip
Edited by jackmax
Couple things.  I downloaded the zip and all that was in it was a text file with some strange characters, no code.
What you maybe talking about is the VI needs to have the compiled code in the .vi file for it to be dynamically loaded.  If you go to the VI properties under the General section there is a check box for "Separate compiled code from source file" you want this off, or else it won't be able to be dynamically called.  Not sure what version this feature was added (around 2009) but if the checkbox isn't there you can't separate the compiled code so there is no issue.
