Good method for detecting walls in a map
Good morning,
I'm spending a lot of time trying to convert a simple map into a set of segments in order to perform a Scan Matching with diferent robot poses for localization. I see there's a huge number of tools in Labview regarding Computer Vision and Pattern Matching but, until now, I can't find anything that satisfies my needs.
I tryed Edge Detection.vi but it returns not only the segment of wall but a complete line from side to side of the ROI as you can try in the example I attached. In addition, Edge detection doesn't work well with diagonal walls.
I could use Contour Detection.vi but it turns out that is computationally expensive according to perfermance profile plus it detects contours as points but I need lines because my map is composed of simple straight lines.
Finally I tried IMAQ Rake 3 but I don't know very well how it works and there's no examples of use in the examples folder.
Labview is an amazing programa with a lot of already made complex nodes, There must be a way to simulate what a robot equipped with a Laser Range Finder or LIDAR would see if running in a very simple 2D room.
Thanks in advance.
Find_Edge_Detection.viFetching info...
I though that was only for detecting circular shapes. I'll give it a try, lets see.
Do you now any node to compute Scan/Line Matching given a map and a set of points defining a contour? Like in the figure I attached.
I initially thought coding the algorithms manually, but since there's plenty of Machine Vision nodes in LabView 2011 I would like to use as much high level nodes as I can. I even saw some LIDAR nodes but they seem to be only for communication purposes, not for simulation.
Thanks for answering.
So, I tested "Spoke.vi" and I compared it with Extract Contour and simulated LIDAR lines. It works perfect for simulating a Robot Scan Match based on LIDAR devices,
Thanks a lot.
post-35621-0-84158500-1371484236_thumb.p
