Dniz Posted January 6, 2005 Report Posted January 6, 2005 Hi, I wonder if any one has the experience of transforming a VI into an executable file so that computers that has no labview installed can still use the User Interface I created with the DAQ card installed. Quote
Bryan Posted January 6, 2005 Report Posted January 6, 2005 In order to build a windows application, you need to acquire a copy of LabVIEW Application Builder from National Instruments for your version of LabVIEW ($600 ish or so?). Also, computers that will be running your EXE version of software will have to have the appropriate version of the LabVIEW Run Time Engine installed. Quote
i2dx Posted January 6, 2005 Report Posted January 6, 2005 Bryan said: In order to build a windows application, you need to acquire a copy of LabVIEW Application Builder from National Instruments for your version of LabVIEW ($600 ish or so?). Also, computers that will be running your EXE version of software will have to have the appropriate version of the LabVIEW Run Time Engine installed. 3390[/snapback] maybe you should have mentioned that you can build an installer package of the vi which allready contains the LabVIEW Runtime Environment (LV Runtime Environment is Freeware ...) with the Application Builder. If you don't want to use an installer but only the .exe you have to ensure that the LV RTE is allready installed on the target machine. the application builder reminds you of that after finishing the compilation ... best regards, cb (tell me if i am a "know-it-alls" ) Quote
Dniz Posted January 7, 2005 Author Report Posted January 7, 2005 i2dx said: maybe you should have mentioned that you can build an installer package of the vi which allready contains the LabVIEW Runtime Environment (LV Runtime Environment is Freeware ...) with the Application Builder.If you don't want to use an installer but only the .exe you have to ensure that the LV RTE is allready installed on the target machine. the application builder reminds you of that after finishing the compilation ... best regards, cb (tell me if i am a "know-it-alls" ) 3394[/snapback] Yes, i would be delighted to build an installer package of the vi. I am not sure whether the application builder is available in the labview version i installed. Is there any way to check it out? Quote
RandyR Posted January 7, 2005 Report Posted January 7, 2005 Dniz said: Yes, i would be delighted to build an installer package of the vi. I am not sure whether the application builder is available in the labview version i installed. Is there any way to check it out? 3399[/snapback] The standard and full version require the application builder to be purchased and installed in addition to LabVIEW. The professional version already includes it. To see if you have it... Go to the 'Tools' menu, if you have an entry there that starts with "Build Application..." then you have it. Randy Quote
Dniz Posted January 7, 2005 Author Report Posted January 7, 2005 RandyR said: The standard and full version require the application builder to be purchased and installed in addition to LabVIEW. The professional version already includes it.To see if you have it... Go to the 'Tools' menu, if you have an entry there that starts with "Build Application..." then you have it. Randy 3401[/snapback] Thanks for the information. I have the application builder in my version of labview When we use the tool to build the application, do we need to open the file to be built or we can just specify the source file from any VI that we open the tool from? Quote
xseadog Posted January 7, 2005 Report Posted January 7, 2005 Dniz said: Thanks for the information. I have the application builder in my version of labview When we use the tool to build the application, do we need to open the file to be built or we can just specify the source file from any VI that we open the tool from? 3409[/snapback] Hi Dniz after you have debugged your development application, save all. Close down Labview then open Labview again, chose a new vi. Select build application and chose the VI you wish to build, rember to include any necessary external libraries. Check that all parameters are set Save the script file. Build the application. If it is necessary to build again ( bugs errors etc) then follow above procedure execept recall build script and modify ie point to new version of main vi. Rember to save script file before building . change its version chow xseadog :thumbup: Quote
