doofus_au Posted December 3, 2013 Report Posted December 3, 2013 Hi, I am new to labview and need some assistance trying to open a .mat file for further analysis (example file attached). The file formate is level 5 and I believe the data is in arrays. I do not have access to confirm the structure but have been told the layout of the data i need to access follows the following structure: MotionFile_walkaround -> Actor_50_human -> Segments -> Sacrum -> Pose. I have successfully read the header and found that byte swapping is required. I have downloaded the Mat-File IO library but have had no success in reading the actual data set beyond the header but assume this is due to my inexperience with both .mat files and labview. Any help would be greatly appreciated. walkaround.zip Quote
todd Posted December 3, 2013 Report Posted December 3, 2013 For reference, here is the cross-post: http://forums.ni.com/t5/LabVIEW/Help-opening-a-mat-file/m-p/2647099#U2647099 Quote
